Well, its not all joy.
We're 25 mins behind set off schedule for Wales and the car is still on the ramp.
Turns out the brembos that were retrofitted have this exact issue on the thread below where the slider plates have lifted, preventing the new pads being installed.
http://forum.a8parts.co.uk/archive/i...hp?t-2710.html
Furthermore, it seems the existing pads that were fitted were sort of shoved in, without pins holding things together properly as the previous 'mechanic' decided it was a tight squeeze too, and just sort of bodged it all......
This in turn caused the pads to sit unevenly on the discs, which have then either warped, or were catching on the wonky pads as the discs were grooved - This wobbling causing me to order new brake discs/pads in the first place.
Ho hum.
No time to sort it 100%, so the a8parts boys are currently working with the old pads, and new fitting kits to refit the old pads safely as being a little worn they will fit better than the new ones in the timeframes we have.
Just another cracking example of a simple job on this car snowballing into a nightmare.
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
