Old 27th October 2018, 05:51 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Hopefully as other posts suggest, a flat battery or power failure has thrown up the majority of these faults.
we've got a Renault trafic in the workshop at the moment - dash it lit up like a Christmas tree. Kept going in to limp mode or simply not starting.
Run our computer over it and had very similar results with almost every CAN module showing power failures/communication errors. Clearing them would not get rid so the fault is current/ongoing.
Started in the engine bay to look for wiring faults or bad connections......the pic says a thousand words.
Wiring has obviously been bodged by a garage at some point and wrapped up in insulating tape. There has been no attempt to even connect the wires properly. Just stripped and twisted together!
Sorry for the post hijack...as you were
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
