Not sure of the exact bandwidth requirements, and it'll probably depend to some extent on what's being mined, but it doesn't need much.
You can certainly mine over WiFi and a 4G LTE connection (I've tried it) but I'm not sure about satellite broadband. Latency might be an issue there, possibly resulting in lots of late/rejected 'shares'. 3G/4G would probably be more reliable if it's available (I'm assuming not, unless the boat is docked).
Having said that, it's easy enough to do a quick test. Just run NiceHash up on a PC equipped with a suitable graphics card and check the performance over the sat connection.
