d4 lowering options
has anyone lowered there vehicle and if so how ?
i have found 2 differant options
1 via installing adjustable links which tricks the suspension into thinking its actually higher than it should be and releasing air to get the correct ride height
2, via a seperate plug in module which after fitting allows you to alter ride height and suspension settings
any info appreciated
cheers
nath
