Old 14th January 2013, 07:47 PM
A bit of a meander, but still on the subject of Xenons....
My new (FL) S8 has standard Xenons with filament main bulbs.
My first observation is that the main beams seem a lot brighter than on my PF S8.
However, being rather more observant I noticed that when switching back to dipped the filament bulbs went out and a fraction of a second later the Xenon beam pattern changed, with a sharp top cutoff (as normal).
So is there also some sort of moveable shutter in there that means the xenons also have a higher beam when not dipped?
My PF S8 the dipped Xenon beams are definitely not changing at all when switching.
Another difference that I've read is that PF xenons have "static" levelling set at start-up whereas my new one has the "dynamic" version.
Yes, yes and more yes.
Your new car has bi-xenons so the xenon bulb is used for high and low beam by means of physical movement of the headlamp inside. The halogen is there only for flashing as xenons cannot warm up fast enough for this.
All FL xenons have xenon self levelling using 2 control arms on the n/s suspension arms.
PF did not have this.
