D2 - Sat Nav, ICE, Audio & TV All in car entertainment discussions |
Bluetooth music on RNS-E?
Now, I’ve joined the TT forum as well. But it’s not as user friendly as this one!
The 2008 TTS I just bought has an RNS-E so I thought I’d be able to use the bluetooth connection to play music from my phone. So it’s all paired and connected; the phone works (even through Siri voice commands) and Siri ‘talks’ through the car speakers, but the music just plays through the phone! Has anyone had any luck with the later A8s with RNS-E? If so, were there any ‘tricks’ in getting it to work? Thanks.
Not sure about how an A8 is set up but I recall looking at this with my son when he had an S4 with an RNS-E. Basically Bluetooth only did phone calls!
We did look at adding an AUX-in connection to play music from an iPhone but never actually got round to it before he traded it in.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Oh dear, not the answer I was hoping for! The phone works fine on bluetooth through my Zooka (speaker bar), so I wonder what’s so limiting in the RNS-E? My daughter’s 2011 A3 system (not RNS-E, but standard Audi stereo system) works fine.
Have you got an iPod/USB connection in the glovebox (aka AMI)? If so that can be used to plug in a tunes2air module which will allow streaming via Bluetooth. If not, it’s probably too expensive to be worth bothering about....
My 2011 S5 doesn’t stream over Bluetooth.....
That's roughly what we were planning for my sons S4. i.e. add an Aux-in connector (needs VCDS to recode the RNS slightly) then a cheap rechargeable Bluetooth/Aux unit plugged into that.
No worries - if it looks like some random proprietary connector, then that'll be it.
If there's no fly leads in there, they came supplied with a USB connector (to plug in a memory stick) and usually an old Apple 30 pin connector. The latter is what's needed to use the tunes2air option. They look like the one in this Amazon link: https://www.amazon.co.uk/Goliton%C2%.../dp/B004I9G486 As an alternative if you have the 30 pin connector, although it's a wired option, you can buy a 30 pin to Lightning adaptor from Apple with a short length of cable and plug a modern iphone in so it charges as well. It picks it up as a source when the phone is connected and unlocked. That assumes you're an iSheep user like me. Failing that a standard USB cable will plug in and support Android via the same method. I use the cabled method with my S5 as it means the phone is tucked away and charging as well as available to play music. It will still connect via Bluetooth for calls ETA - can't find any results for tunes2air on Amazon now (worth checking ebay for used ones) but this looks like the same device: https://www.amazon.co.uk/Bovee-Wirel...J6S7J3HD1PNA2T
The wired option sounds good, as I'll need to charge the iPhone anyway. Here's a photo of the connector socket in the glove box
2002 Final Edition S8. Ebony black with Silver Grey leather and myrtle wood trim. Current mods: solar sun roof, 20mm rear spacers, 15 mm on front, red brembo callipers, 6k headlights, rear view camera, engine remap, alloy dash dial rings, alloy navi rings, tt/phaeton pedal upgrade, (and custom matching foot rest) dension ipod interface & parrot hands free kit (both fully hidden), av input, tv in motion switched thro' PF switch in blanking plug right of steering column, Audi 'quattro' sill covers, repositioned centre console switches, radio clock, .Planned mods: auto-dimming rear view mirror, dash cam (as steamship's), fit the ski hatch, refit philips drl's (or maybe not - nope, definitely not - horrible botch!). Last edited by The_Laird; 15th January 2020 at 10:15 AM. |
That looks like an Apple 30-pin interface for older Apple devices, so hopefully you just need an adapter to connect newer ones with a lightning socket.
Jim, can you take a better photo, closer and in focus? Note: If that is the case you will probably need to shell out on a genuine Apple unit as most 3rd-party ones either only support charging or will be rejected by newer versions of IOS as not being compatible.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 15th January 2020 at 10:27 AM. |
I’ll try another photo later. I tried to fit an old 30pin connector to it, but my sausage fingers wouldn’t allow it!
