VCDS (aka Vagcom) For all your electronic debug / diag advice queries and mods. |
Hmmm Vag Com Help.....
This is what my car is throwing up at the moment... Any ideas which part(s) to replace
She's running fine (power wise) just the orange light on the dash showing engine fault?? Only thing I would say is she seems to have aquired a "bass line" One thing I might add is the car has good rythem Many Thanks Bex 005504 - Throttle Actuator (Bank 1): Malfunction P1580 - 008 - Implausible Signal Freeze Frame Fault Status: 01111000 Fault Priority: 0 Fault Frequency: 6 Time Indication: 0 Date: 2010.06.12 Time: 17:07:35 Freeze Frame RPM: 0 /min Torque: 0.0 Nm Voltage: 12.31 V Duty Cycle: 82.9 % 004203 - Throttle Valve: Stuck or difficult to move P106B - 001 - Upper Limit Exceeded - Intermittent Freeze Frame Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 254 Time Indication: 0 Date: 2010.06.18 Time: 22:11:34 Freeze Frame RPM: 777 /min Torque: 93.6 Nm Voltage: 4.080 V Duty Cycle: 61.2 % Duty Cycle: 7.5 %
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close. |
P1580 Throttle Position Actuator (V60) dirty/stuck/faulty P106B is P106B Could be - 1) Wiring/Connectors from/to Throttle Body Control Module to Engine Control Module faulty OR 2) Throttle Body Control Module Damaged and/or Moving Difficulties Click on the code links for a fuller explanation in both cases HTH
Confidence is the feeling you have before you know better . . . . Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs |
Try to clean the throttle body.
Remove the inlet pipe and clean out with a brake-cleaber soaked rag. Make sure you get right into the corners of where the mounting rod is and DON'T DROP ANYTHING IN OR GET YA RAG STUCK IN IT!!! Breather gases can make oil vapour and carbon deposits build up in the housing that eventually restricts the throttle plate's movemnt. Cleaning it may help but you then need to re-adapt it. Plug in VAGcom, ignition on. Into Engine and select BAsic Settings. Type in 060 in the block field and hit return. It will show some movement in terms of either a percentage of travel or a current draw in milliamps. In the right hand block it will say "ADAP RUN, then ADAPT OK when it's finished. You'll here the valve moving. Once it's done just exit and clear any faults. Then start the car WITHOUT touching the throttle pedal. If this doesn't work you may have a duff wire or knackered valve! Good luck. p.s, I'm assuning you have the 40v not 32v, if you have a cable operated throttle as a possed to full drive by wore one then the basic setting figure os 098 istead of 060 but same procedure. |
I was understanding until what I have highlighted bold. It's a 3.0 TDI if that helps When I pop the engine cover off I can see a few bits moving backwards and forwards... this in in perfect timing with this "basey" noise I have coming from the exhaust Now, not sure if this is anything to do with it, but it seems I have VERY slight power surges when on the throttle (steady throttle i.e not moving throttle position) Bloody car! Every time I polish it it wants something done to it, whether it be brake pads or a bloody service! lol Good job I love her!
AH!!! My bad!
I never even considered it being a diesel! In that case it will be due to a severe carbon build up within the intake manifold. This may be a bit more involved though due to this engine and it's design. Be sure to buy your diesel somewhere good - cheap fuel causes huge build ups and can damage your common rail injectors quickly!! Always try to use Shell or BP where possible - NEVER any supermarket or Spot fuels ect! You are gonna have to have inlet tract off and physically remove all the build up I would say with those faults. Apologies again for assuming your motor was petrol! I should have read up as on many earlier posts you are pretty clear!! |
can I put a fuel cleaner in to help??? Any you would recommend???? I have to admit I have used sainsburys fuel recently??? Should I go and use V power Diesel from shell??? Thanks for all your advise-if you were closer I'd be bringing it to you guys! lol
