Low oil pressure warning
Easing my way through the Hindhead road works on the A3 yesterday afternoon and my low oil pressure symbol appears on the DIS accompanied by 3 beeps. After the 3 beeps the DIS returned to normal.
I stopped as soon as I can and the oil level was good, ands on restart and the rest of the days driving there were no further anonalies. Is this most likely a sensor glitch? Is this a common fault on D2s? Am I right in thinking that if the low oil pressure symbol on the DIS goes off, the oil pressure is OK? |
I've done a VDCS scan and there were no oil pressure related faults so I am guessing that;
1. There was mo loss of oil pressure. 2. The DIS has its own independent sensor. 3. An intermittent fault with this sensor or its associated wiring caused the DIS warning. It hasn't happened again since, and hopefully it won't happen ever again |
If the dip stick says it's ok. It should be ok.
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
its a slim outside chance but if the oil is getting on a bit (and getting a bit thin) , the engine is getting on a bit (so fractionally down on oil pump efficiency) and it got very warm sat in the traffic (making the oil even thinner) it could possibly have got the oil pressure just low enough to briefly trigger the warning? Going back a year or 10 my old rover v8 used to have virtually no oil pressure when in traffic and hot for the same reason, but even the slightest bit of engine speed (above 1200rpm) and it was 30psi! Can't imagine the audi 8 doing it but it might explain its very random shortlived appearance?
Hopefully it is just going to be one of those unexplained things. |
