Old 22nd April 2016, 06:58 PM
Artermis Artermis is offline
Default Replace analogue TV with DAB module
Hi everyone
Had a thought. Is there any reason why I can't replace my TV analogue module, obviously now obsolete, with a DAB module. Saves messing about with cabling etc surely and connectors are all cross compatible aren't they?
Current: 2004 D3 4.0 TDI V8 in Crystal Blue.
Factory: finger print, tv, xenons, keyless entry & go, soft close boot, 19s, and probably lots more besides
Done: fixed headlight washer leak, fit Bluetooth in place of factory phone
To do: DAB, DTV, fix soft close boot, get a spare key, investigate NSF bushes,
Old 22nd April 2016, 07:03 PM
im guessing you mean with a hybrid tv tuner , DAB is the radio
you can simply swap one unit for the other in this case
Old 23rd April 2016, 03:37 AM
Erm, no...... Lol
I mean I've bought a DAB tuner to fit to the car. Car came with the now defunct analogue TV tuner.
The TV tuner is obviously dead weight as no more analogue TV signal, so it's doing nothing.
What is to stop me, rather than butchering wiring and adding in power cables and MOST optical cables just removing the TV tuner and fitting the DAB unit instead?
Essentially using the cars MMI harness plugs from a unit I can't use with one I can to save purchasing / adding additional wiring if not needed. I obviously realise that DAB is radio not TV lol
Old 23rd April 2016, 06:19 AM
Burnzybubbles's Avatar
I don't see why not, as you say the MOST is just a loop and doesn't determine what goes where, I can't remember what plugs are on the tv and if they will swap over to the radio, I know half the time it just a standard set of power cables for most modules.
Then just code tv out of the options list to save yourself from any errors
Old 23rd April 2016, 06:37 AM
but why bother , i thought the dab install was easy enough , its adding the antenna in which is more of a job
Old 23rd April 2016, 06:44 AM
Somerandomguy's Avatar
In principle yes, it just needs power MOST and antenna.
The thing to watch out for is that the antenna cables are "keyed" differently so will need to be eitther changed or used an adaptor pigtail.
From memory, the TV fakra connectors are green and brown, whereas the DAB is black.
This shows the differences http://www.co-star.co.uk/images/pdf/FAKRA%20LIST.jpg
2004 A8 3.0 TDI Sport Brilliant Black
Came with: Black Valcona/Alcantara Leather, KESSY, rear blind, flappy paddle gear change, Phone Prep, TV
Added:Bluetooth, AMI, Hybrid TV, Parking plus, Ski hatch, towbar, DAB, Umbrella Holder, Reversing camera, Auto lights, Wheel refurb
Things to fix: Turbo fault, power drain
Old 23rd April 2016, 07:51 AM
ColinR32 ColinR32 is offline
Speaking from very very recent experiance id buy the hybrid tuner all day long,
Literally unplug the analouge tuner and replace with hybrid
If need be update software on mmi and hey presto flawless digital tv with superb picture quality
I done this just last week with a little
Help from the good lads on here
Daily Driver- Audi A8 3.0TDI D3 Mmi 2g high
reg- A8CPX
installed- bluetooth, hybrid dvbt tuner, aux input, finger scan, soft close boot,suspension lowering links
Old 23rd April 2016, 08:00 AM
i did mine - changed the analogue to the hybrid unit, was lucky enough to get the unit half price from a8parts at one of the open days.
still it was something i thought i had to have, since then i must have used it a couple of dozen times, the kids watch their movies all the time, but rarely the tv, so in theory i could have just stayed with the analogue.
like so many of the retrofits the must have becomes a rarely used toy
Old 23rd April 2016, 11:59 AM
That is my thinking entirely with the TV tuner - am I likely to actually watch TV? I've had TV in previous cars realistically not used it.
DAB on the other hand I would listen to so to save having to do any wiring mods just ditch one for the other; I don't see the need for messing with the wiring unless absolutely necessary. Less I mess with less to go wrong and there is the plugs and connectors sat there essentially going to waste as the analogue TV tuner is utterly useless of course.
Old 23rd April 2016, 11:00 PM
DAB sucks... it's often worse than FM as its often mono and lower equivalent bitbrate. Better spending the money on an a2dp receiver and maybe a large data contract to stream the signal.
