Old 29th October 2017, 07:47 PM
Default T8 @ MJs
I took the Trader's 8 in to MJs today and I was met with this.......
Probably the greatest number of D2s owned by a single person! Yes, MJ now has 4! Mine is on the end in the photo but there is her FE out back!!!!
I shall have to buy another two now
Old 29th October 2017, 08:10 PM
For the record today was an annual service and MOT prep.
Planned work included a prop-shaft swap, rear spring replacement, split the custom one piece exhaust, fit an engine under-tray and handbrake cable change.
The handbrake cable turned out to be a duff caliper, on a Sunday, with the nearest replacement a 2 hr round journey away, which I did while MJ completed the service.
The nasty rattle that I thought was the exhaust rubber mount failed turned out to be a ARB C-Link.....which (of course) MJ had a spare in spares box number 146A-B1.
So in 7 hours the two of us removed the exhaust, split it, fitted two new sleeve connectors, removed the prop shaft and all the associated heat shields, removed and refitted both rear springs, removed and refitted a rear brake caliper. While I was fetching the replacement caliper MJ did the annual service and fitted the under tray. We then refitted the prop-shaft. Put everything we had taken off back on, replace numerous fixings that hadn't come off in the designed manner, replaced with some non OEM but better fixings and fired it up on first turn of the key!
For Neil; I only ate 2 Jaffa cakes and a bag of crisps, that's how busy we were!
Took it out for a wee rampage, no thump when driving in TIP. No rattle on bumpy roads and the back end is a lot less saggy.
Don't need to cross my fingers for the MOT tomorrow. MJ did the prep.
Old 29th October 2017, 10:27 PM
Spanker's Avatar
Spanker Spanker is offline
I didn't know about the T-reg one.
That was kept quiet.
I think the "more the merrier".
Here's another one that can be added to the collection:
https://www.gumtree.com/p/audi/audi-...002/1273086461
and it's just down the road
(would a red trim look good in a red car???)
Dean
Old 30th October 2017, 03:51 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
...that's a cheap FE (if it is) and a replacement head can be sourced from our sponsors at the right money
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 30th October 2017, 07:32 AM
Yeah, right!!
I already sent MJ the link last night as soon as I saw it haha
Old 30th October 2017, 08:44 AM
Spanker's Avatar
Yeah, right!!
Great minds think alike
It had her name written all over it.
Dean
Old 30th October 2017, 10:45 AM
Mm so did the last one...
And the one before that...
No space or cash left for another one I'm afraid
Old 30th October 2017, 12:17 PM
Ameiseuk's Avatar
I think he's going to break it
Daily drive:
Current 'Project':
2000 Audi S8 FL
www.whall.co.uk
Old 30th October 2017, 04:19 PM
Trader's 8 now has a fresh MoT Some slight shenanigans as the DVLA system crashed halfway through the test (wasn't me honest!) but I'm assured they will print out the certificate just as soon as it's fixed...
I reckon that one on Gumtree probably is an FE, but he's a bit high on the price with no 20" wheels. With a blown engine, the interior is really the only big ticket item left since the gearbox is unknown and the calipers are undoubtedly seized. From the description I'd say its dropped a valve, the same as my FE did, so the bottom end will be toast as well. S8 engines are getting very scarce now so its very likely a breaker unless someone has a ratty body with a good engine.
Can I clear some room in time to put a cheeky offer on it...?
Old 30th October 2017, 06:31 PM
After seeing your unit (and without being judgmental here MJ ), "clearing some room" could take you a bit of time without some serious help!
