Old 17th November 2014, 09:05 PM
SilverS8 SilverS8 is offline
Default "How to" Central locking pump removal and motor change.
Hi.
My FL S8 started blowing the fuses for power windows and central locking just by pressing they keyfob some time back. so here is how I fixed it.
The 00 S8 has a unit 8L0 862 257 G which seems hard to get and overpriced so i managed to get a hold of a similar unit with L. According to Etka G replaces L so this should be straight forward but thats not the fact i'm afraid. it would not work on remote opening/closing
Location of the pump is behind the CD Changer on the left side (Uk pass side). Remove the CD Changer and Nav unit along with the metal pieces its mounted to. Disconnect any wires. there are 2 plastic plugs facing down from the top of the booth. gently pull the middle piece out and remove the remaining.When done the interior can be pulled out plenty enough to get to the pump out which you will find stuffed in a foamy "House". Remove and disconnect the 3 connectors and the 2 vacuum lines
ID:	9529   Click image for larger version
ID:	9530   Click image for larger version
Name:	Pump Location.jpg
ID:	9531   Click image for larger version
Name:	Pump ready to be disconnected.jpg
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 17th November 2014, 09:07 PM
Then you have your pump out and ready for inspection.
Carefully pry the cover off(it's easy to see how they are locked in place)
Name:	G unit unopened.jpg
ID:	9532   Click image for larger version
Name:	L unit unopened.jpg
ID:	9533   Click image for larger version
Name:	Both units opened.jpg
2000 Silver S8
Old 17th November 2014, 09:23 PM
Gently wiggle out the circuit board, by pushing carefully on the connectors it almost falls out.
I immediatly saw the difference on the circuit boards and no wonder the L unit wasn't a straight swap.
Since my pump surely had some electrical difficulties i opened up the cover of the pump/motor (Three screws ) carefully lifted the lid and did quickly see what caused all the fuss.. The plate that moves around was shed to pieces, most likely stopping the motor from turning and therefor causing the fuses to go bye-bye.
ID:	9538   Click image for larger version
Name:	Board removed G unit.jpg
ID:	9539   Click image for larger version
Name:	G Unit circuit board.jpg
ID:	9540   Click image for larger version
Name:	L unit circuit board.jpg
2000 Silver S8
Old 17th November 2014, 09:43 PM
Remove the motor from the housing by pushing down the 4 rubber tips on the top. I used a regular flat scredriver. At the same time wiggle carefully out the vacuum pipe(light force with a plier might help)
Once removed from both units, use a small plier or a knife to free the cables from the motor housing(easier then cutting and soldering back togeher)
Or if you love soldering is possible to remove the complete cable directly from the circuit board
I did open the motor that was working in the L unit but no pics of that i'm afraid
After you have figured how you will do the cables, put the new/exchange motor back into the housing, pull the rubber tips all the way up until you see that they are in place, at the same time carefully put the plastic pipe back in where it was be and insert circuit board before snapping the bottom cover bak on.
Then its ready for installation and all should be good.
Since i could only upload thumbnails any moderator are welcome to alter this thread in order the make it more understandable if needed
ID:	9544   Click image for larger version
Name:	Vacuum hose from pump.jpg
ID:	9545   Click image for larger version
Name:	Motor Connectors.jpg
ID:	9546   Click image for larger version
Name:	MacGyver Trick.jpg
ID:	9547   Click image for larger version
2000 Silver S8
Old 19th November 2014, 09:15 PM
Thanks for the write up! Added to sticky
Old 4th March 2015, 01:35 PM
Alluminio's Avatar
Alluminio Alluminio is offline
Another big thumbs-up to SilverS8 for this thread; my central locking pump failed a few days ago and with this write-up and the images (and a repair kit form Ebay) the pump is now back to 100%.
