Old 5th September 2016, 07:43 PM
Default Bird Cr@p Removal
One of the problems of living near the sea is the frequency of ****ehawk attacks. As bird cr@p contains uric acid unless you get to it quick, it burns into the gel coat. I was too late getting to one on the drivers door and despite giving a good going at with the DA polisher with Fareclas G3/G10 two weeks ago it was still there. So today i resorted to good ol' wet and dry. Gentle rubbing with some 3000 grade got rid of most of the mark (and some of the gel coat!) before some G3 using a small hand pad, followed by some G10 applied in similar fashion. Some Poorboys Black Hole glaze and Natty's paste wax and all was good.
Photo 0292 shows the mark although its hard to see in the reflected light. 0302 shows the end result.
ID:	14312   Click image for larger version
ID:	14313   Click image for larger version
ID:	14314   Click image for larger version
ID:	14315   Click image for larger version
ID:	14316   Click image for larger version
ID:	14317   Click image for larger version
ID:	14318   Click image for larger version
ID:	14319   Click image for larger version
ID:	14320   Click image for larger version
Old 5th September 2016, 08:16 PM
Turbo Tony's Avatar
Good going!
Storytellers Villa Orlando
2008 Audi S8
Old 5th September 2016, 08:44 PM
sarg sarg is offline
Apparently they eat grit and sand to aid digestion so you have to be really careful even with fresh ****e removal
I use extra deep pile microfibre towels after a blast or two of quick detailer
2019 BMW M5 (my daily driver)
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 5th September 2016, 09:00 PM
Nice work David
But prevention is better than cure of course:
http://i.imgur.com/GojT6w1.jpg
Old 5th September 2016, 09:57 PM
Good result not sure I would have the confidence to hit it with the wet & dry
Old 5th September 2016, 10:01 PM
1781cc 1781cc is offline
Here's a tip, best way to remove it initially is sparkling water, the carbonation reacts and bubbles it up and off naturally removing any grit
I always keep a small 35cl bottle in the car
Old 6th September 2016, 08:03 AM
Top tips! The 12 gauge would work on dogs and cats in the garden too!!
Brian: If you want to bring your '8 around we could all have some practice at wet&dry techniques. John (47P2) did his RangeRover all over and it didnt ccome out too bad.
Old 6th September 2016, 10:31 AM
Brian: If you want to bring your '8 around we could all have some practice at wet&dry techniques. John (47P2) did his RangeRover all over and it didnt come out too bad.
Now, I have a couple of scratches that probably need wet and dry, but I don't have the b***s either. Perhaps one fine weekend I could tempt you with a couple of ciders!
