D2 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
I have been told, "no cant do that mate"!!!!!!
Hello, I have just got hold of a 1998 S8 with 255/45/18's on the back and 245/45/18s on the front. The front's are now on the limit and need changing, I got hold of some nearly new tyres from a mate that does track day racing in a Toyota Soarer after he changed them for track tyres but they are 245 40 18s. I have been told by the tyre fitting place that he would not fit them as my car is 4x4 with traction control as they will nacker the gearbox/transfer box????? is this correct
or will they be OK to use. I also had a word with my local Audi place and they told me to buy 4 new tyres as my car should have 245 45 18s. Any advise will be greatly excepted. Thanks Mick |
Mick,
The commonly held belief is that rolling radius must be with 1% so you don't damage the quattro section of your transmission. You currently have 1.33% difference with your set up which you may just get away with. Switching to 245-40/18 will increase the difference to 3.71% smaller on the front and you are heading for a whole world of hurt. If you want to run a staggered set up then ensure the tyre's rolling radius is within 1%. I have a staggered set up on my projekt of 285/30-20 rear and 245-35/20 front. .07% difference, works fine. The arches are modified. Workable combinations and wheels for our cars is here. There is a good calculator here and lots more information besides. HTH
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
Thanks for the info.
Blimey, so there not just rubbery things on each corner there is science behind it. So if I keep them all the same size on all four corners I guess that will be ok? The backs are nearly new so don't want to change them if I can help it. (255 45 18) so I will have to go and get some new 255's My mate with the track day car said about trying FALKEN tyres, are they any good bearing in mind it is a family drive not a track car and then only really used at weekends as I have a work van during the week. |
Try to keep the same make / model of tyre on all four corners if possible. If not Falkens are a good mid range tyre.
