Go Back   A8 Parts Forum > A8 D4 > D4 - Transmission
D4 - Transmission Gearboxes, diffs, drive shafts.
Old 16th February 2021, 05:00 PM
Slabber Slabber is offline
Default Sport differential: System fault dash warning
I was alarmed the other day to get a Sport differential: System fault dash warning on my 2010 4.2 TDI. On pulling the codes with VCDS I've got
0262 - Oil Pressure and Temperature Sensor: C1004 01 [008] - Electrical Failure
0280 - Oil Pressure and Temperature Sensor: C1004 FF [008] - Oil Press. implausible Correlation with Sensor 2
Oil Pressure and Temperature Sensor: C1004 31 [136] - No Signal
There's not a huge number of posts about this for the D4, however seems to be the same as these posts from Nath: 1 | 2. As per Nath's issue hopefully mine is just sensor(s). Has anyone else had this and can confirm?
