Timing Chain or Belt?
Hi All,
I'm looking at doing the timing belt on my new purchase but I'm getting conflicting answers as some say its belt driven and others are saying its a chain? does anyone know which it is thanks? Last edited by Sinner2004; 9th October 2022 at 01:03 PM. |
Timing belt.
It does have chains driving the inlet cams from the exhaust cams but they're not a service item on the 32V engine. Finding parts for the 32V is a significant challenge these days, with the tensioner roller being pretty much unobtanium. The FB groups are probably your best bet as new old-stock items turn up from time to time. You need the cam and crank locking tools to hold the engine in time while you set the belt - Prestige (A8parts) have these which they rent out. You also need a replacement crank sprocket bolt and a ginormous torque wrench which can do some 400Nm. I borrow a five-foot-long 1" drive beast of a thing from the local tractor workshop! |
Almost everyone with a D2 knows it's a belt, though there are chains further inside the engine.
And there's a load of other jobs best done at the same time as changing the belt(s), but I'll let the experts list them, I only pay for others to do them on my car.... Edit: "I'll get my coat". Resident expert was typing at the same time.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
1998 A8 4.2 V8 Quatro in silver (in process of getting back on the road) 2005 Discovery 3 2.7 TDV6 HSE (The Wife's) |
The best advice I have for doing this job in the car is to buy a few sacrificial but good quality 8mm allen keys which you can cut down to the appropriate length for each bolt, as almost all of them are blocked by the chassis leg for virtually every combination of bits and extensions normally found in a toolbox. Also use a long extension bar or long centre punch to give each bolt a solid whack with a hammer before trying to remove them - this can help break the stiction in the threads so that they will come out without stripping. Do not use ball-end tools in them - they will snap or strip and then the engine has to come out to drill the heads off. My standard quote for a timing belt on a car I've not seen before is 2 days, because the bumper bolts and front panel bolts can seize in place and make it quite an ordeal to get apart. If it all comes apart nicely then bonus, but if I haven't worked on the car before I'll assume its all seized and plan accordingly. The last one I did took 14 hours, in one day Add half a day to that for the oil cooler pipe. |
How much would you charge to do the job? Including parts ?
Another Rugby resident huh? Where are you?
Yes, but you did have me hindering you so you could probably have shaved a few hours off for that
Dean Future work on "Red Dwarf": Fridge, solar sunroof, radio-controlled clock, interior and exterior dimming mirrors, Alcantara headlining/pillars/rear shelf, rear US outer lights, passenger memory seat, rear electric (lumbar and headrest) heated seats, Servotronic. __________________ Current: 2002 A8 D2 S8 FE - "Red Dwarf" - Misano Red - Platinum/Silver Interior, PDC, Sat Nav Plus with BOSE and hidden Dension Bluetooth, Multi-changer, Heated Front Seats, Bi-Xenons, FE Wheels, Phone Prep with Nokia 6210, Detachable Towbar, Rear Blinds, S8 plate but no other optional extras 1st Place Winner - A8Parts Annual UK Meet 2018 1st Place Winner - A8-Freunde Annual German Meet 2018 2nd Place Winner - A8-Freunde Annual German Meet 2019 2002 A8L D2 with a factory fitted S8 engine and drivetrain - "Evergreen" - Irish Green Pearl (TBC) - magnolia leather seats with magnolia door cards/door trims, magnolia leather head-lining, extended leather pack 3 (dark green leather dash, upper door cards, steering wheel, lower dash, centre tunnel and rear parcel shelf), factory black external trim (in lieu of chrome), self-levelling suspension, Servotronic, Brembo brakes, "gullideckel" / "man-hole cover" / "pie-plate" 8Jx18 polished 10-hole design wheels typically seen on the W12, Park Distance Control, heated windscreen, multifunction steering wheel, Vavona burl (burr-walnut) wood inserts with cream/magnolia door switch trims, phone preparation to the front with Nokia 6091 phone, phone preparation to the rear with Nokia 6091 phone on the central rear console, third phone preparation in the rear centre console, rear blinds, rear headrest release feature, rear electric heated seats with lumbar and recline function (the rear passenger seat has the facility to move the front passenger seat forward), BOSE audio, Rear Screen Entertainment (RSE) with dual factory fitted Alpine screens, integrated DVD player (under the centre of the rear bench with 4 DVD storage slots) and two remote controls (the controls and inputs for the RSE are in the rear centre console and the screens can operate independently of each other,) factory supplied leather headrest covers to hide the rear screens, rear vanity mirrors (standard A8L), dark green rear wedge footrests with cream piping, front passenger memory seat, dark green floor carpeting and mats – piped in cream, rear slumber pillows for the headrests, integrated fridge with integrated tumblers inside the rear centre headrest bar compartment, solar roof, auto-dimming interior and exterior mirrors, factory driver’s seat fire extinguisher, tire pressure monitoring system, first aid kit, 12 V socket in the boot, TRACKER, derestricted – top speed is 155mph plus 2007 A6 Allroad C6 3.0TDI Quattro - Highland Green (Audi Exclusive Colour) - Cream leather interior with Wood, Advanced MMI, Keyless, Bose, Advanced PDC, Sunroof, Heated Memory Seats, Adaptive Xenons, Adaptive Air Suspension, Servotronic Previous (went to good homes): 2002 A8 D2 2.8 Quattro Sport - "Big Red" - Tornado Red (Special Order) - Twist Interior, PDC, Passenger Memory Seats, Symphony II with BOSE, Heated Front Seats, Bi-Xenons, Auto-dimming Mirrors, 20" FE Wheels, Servotronic Steering 2002 A8 D2 2.8 Quattro Sport - Aqua Blue Pearl - Twist Interior, PDC, Sat Nav Plus with BOSE, Multi-changer, Heated Front Seats, Bi-Xenons, Auto-dimming Mirrors, Avus Wheels |
