Old 3rd June 2015, 10:28 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default S8 Anti-roll bar
Random thought.
The S8 runs a larger Anti-roll bar that my TDI and possibly other A8s.
Has anyone fitted a S8 Anti-roll bar to their A8?
[center]
06 3.0TDI Quattro:
Options:
Old 4th June 2015, 07:44 AM
NightOwl NightOwl is offline
Its on my to-do-list, but not done yet.
2006 Audi A8 3.0 TDI Quattro Sport
A8 W12/S8 Brakes front and rear (385mm/335mm)
Focal and JBL speakers, Helix amps
S8 anti-roll bars front and rear
Complete rear LED taillight
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 4th June 2015, 08:26 AM
I think Sport and S have the same antiroll bars, non Sport have smaller, at least that's how it usually is on Audis. And RS models usually only have rear antiroll bar stiffer than S/Sport models but the same on front.
Old 4th June 2015, 12:27 PM
It changes through the model years and engines, but as for the 2006 model:
PR-codes:
PR-1BK+T15, T41,T81, T82, T14, T8T, T44 Anti-roll bar size 30,3X3,4 mm. Part number 4E0411305AA.
PR-1BK+T42, T1H, TB1 Anti-roll bar size 30,8X3,5 mm. Par number 4E0411305AB.
PR-2MA+T15, T41, T81, T82, T14, T8T, T44 Anti-roll bar size 30,8X3,5 mm. Part number 4E0411305AB.
PR-2MA+T42, T1H, TB1 Anti-roll bar size 31X4,7 mm. Part number 4E0411305AC
PR-2MB+T8E Anti-roll bar size 31X4,7 mm. Part number 4E0411305AC.
Out of this, we see that the 4.0TDI, 4.2TDI and W12 with sport suspension has the same size anti-roll bar as the S8.
1BK -> normal/standard suspension.
2MA -> sport suspension.
2MB -> sport suspension S8.
This was only for the front, and for the rear:
Here I don't have the size, but I can compare the part numbers.
PR- and engine-codes:
PR-1BK+BFM, BFL, BAR, BPK, BVJ, BHT, BSB, BSM, ASN, BNG, ASB has part number 4E0511407D
PR-1BK+ ASE, BHT, BTE, BVN, BMC has part number 4E0511407J
PR-2MA+ BFM, BFL, BBJ, ASN, BAR, BPK, BFM, BGK, ASB has part number 4E0511407J
PR-2MA+ ASE, BHT, BTE has part number 3D0511407B
PR-2MB+T8E has part number 3D0511407B
Here we see that the 4.0TDI and the W12, both with sport suspension, has the same rear anti-roll bar as the S8.
Not so complicated after all?
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 4th June 2015, 01:21 PM
There's also a 31X5,5 mm roll bar, 4E0411305R, PR-2MA+T42 which is from the 8-cylinder diesel engine 4.0 L Unit 057.B
Matt
Old 4th June 2015, 01:48 PM
True. But for my understanding its not for 2006 model, although I'm pretty sure it will fit.
Edit; actually the 4.0TDI was discontinued in 2005, so it shouldn't been in my list at all.
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 4th June 2015, 08:33 PM
ScottD3's Avatar
Not a massive difference.
Not as big as I was expecting.
Be interested to see what difference it makes though.
[center]
06 3.0TDI Quattro:
Options:
Old 4th June 2015, 08:37 PM
Going by Tdum's level of motion sickness I would say not a lot
Old 5th June 2015, 08:29 AM
I guess it depends what you are after.
Personally I think it could be interesting to see how much better cornering the S8 anti-roll bars will give with the smaller, lighter engine, as its designed to fight the weight of V10, W12 or the heavier diesel engines. Less under-steer, and less tire wear would be welcome to me, driving mostly winding country roads.
The front is a simple pick-of and bolt-on operation, while the rear is a bit more challenging as you need to remove the trailing link on both sides, which also has an eccentric washer...
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 5th June 2015, 08:46 AM
Stiffer at the front will give you more understeer, stiffer at the back will give more oversteer (or less understeer)
