Swapping 5 speeder for 4 speeder
anyone any comment on if this is possible? I'd naturally assume you would need the gearbox ECU as well but other than that is it a major piece of work to swap from a 4.2 early 4 speeder into a 4.2 '97 5 speeder?
From the post that suggests the 4 speeder is robust enough that its covering huge mileage without concern I'd be happy to trade a little performance hit for piece of mind that my gearbox isn't about to blow up every two mins. |
I think you need a new diff (not 100%), gearbox ECU and a new gearbox selector surround. I'm sure someone else will add to that but It is possible to swap them over.
2009 Audi RS 6 Saloon V10 - 420mm Ceramics, Keyless, Soft Close, Adaptive Cruise, Glass Sunroof, Blinds, Twin Pane & UV, Freeview & DAB, High Beam Assist, MTM bits, Audi Exclusive Bits, MRC, Milltek, GYEF1 ASY2's, Bluetooth streaming music to AMI mod - 753 PS/1021 NM 2016 Audi S3 Saloon, Sepang, S-Tronic - B&O, Tech Pack etc... Company Car 1995 Audi A8 4.2 V8 quattro Sport - Bose, Solar, Blinds |
You might get away without the diffs, but it depends on the ratios.
You may also need a different engine ECU as some of it needs signals from the tranny ECU. If you use the audiworld forums, the guy to as for is TozoM8.. He is the A8 gearbox god over there, converted his A8 to manual (auto only in the US too) and has rescued many a box for other members. |
Cheers Gents!
