Go Back   A8 Parts Forum > Our Other Audi Friends > A6/S6/RS6 C7
A6/S6/RS6 C7 2011 Onwards
Old 6th November 2016, 08:21 PM
Conquistador's Avatar
Default Disabling start/stop by default from engine on
Anybody happen to know if it's possible to disable start/stop by default on a 2014 A6 (TDI 3.0-litre) with VCDS?
Audi said it can be disabled by default, but they will not do it.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 6th November 2016, 08:39 PM
kele kele is offline
I did so on my c7 as follows:
Disable Start / Stop
[Select]
[09-Cent. Elect.]
[Security Access - 16] (enter security code - 20113)
[Adaptation - 10]
Select Channel 34 and Read
if you subtract 4 from the original value. Test then save --> Start&Stop always disabled
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment
2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot
2022 Mercedes EQC 400
Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS
2008 A8 3.0 Tdi sport, B&O
Old 6th November 2016, 08:43 PM
I've got a button on the dashboard in A3 for disabling it.
Dont know if thats permanent until pressed again or it lasts only until next time you start the engine.
I can check it tomorrow
(in the bed with Jack Daniels )
Old 6th November 2016, 08:46 PM
Looks like Kele solved your problem while I was typing my reply
Old 6th November 2016, 08:47 PM
If it is like the dash button on mine, then it resets with engine off. With the adaption you don't have to worry about switching it off at every start up....
Old 6th November 2016, 08:51 PM
Thanks. That coding above looks promising so will give it a go ^ ^ ^ ^ ^
It's for a friend of mine and he doesn't like the start/stop activating on every start. Instead wants it off all the time.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 6th November 2016, 08:59 PM
On the D4 you can play with the logic, reverse the button so you have to switch it on, set it to be sticky (remembers if it is on or off) or just disable all together
Old 6th November 2016, 09:02 PM
Disable/memorize/invert Start & Stop
[Select]
[09-Cent. Elect.]
[Adaptation - 10]
if you subtract 4 from the original value --> Start&Stop always disabled
if you add 32 to the original value --> memorize last status (the Start & Stop status at engine startup will be the one at last engine shutdown)
if you add 64 to the original value --> Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled.
Press Test then press Save
