It isn't possible mate, I'm afraid.
There are four screws that hold the platic-chrome plated trim piece in place. You can access two of them but the other two are mounted to the switch / sensor assembly. These two screws are then completely inaccessible once the handle itself is all bonded together.
I wouldn't recommend drilling them out as there is a bunch of circuitry below that relate to the keyless opening, which leaves your only option of trying to cut those clips off which I guess could be done with a dremel if you're careful.
Current: 2004 D3 4.0 TDI V8 in Crystal Blue.
Factory: finger print, tv, xenons, keyless entry & go, soft close boot, 19s, and probably lots more besides
Done: fixed headlight washer leak, fit Bluetooth in place of factory phone
To do: DAB, DTV, fix soft close boot, get a spare key, investigate NSF bushes,
