Old 28th December 2022, 09:56 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Default Snapped washer jet connector thingy
I’m not really sure which section this question should be in
Well, I have another coolant leak which appears to be coming from a busted rad (again )
As I was pulling the bumper off to have a look it jolted forward and snapped the plastic washer pipe connecting piece as pictured - many swear words were said because I was trying my best to ease it forward slowly .
If any of you have attempted to remove the front bumper you’re probably aware how little slack there is but to get to it easily before hand you really need a ramp to attack from beneath or remove loads of gubbins by the drivers side. I tried to save time but i ended more vex with myself in the end.
Does anyone know the part number please so I can order a new one please
ID:	29154   Click image for larger version
2016 S5 Coupe Black Edition - Ibis White
Old 28th December 2022, 10:04 PM
1j0955665e
Old 28th December 2022, 10:08 PM
RICKY D's Avatar
Somehow I knew you probably be first to reply…and know the part number!
Thank you MJ
