Cant enable hidden green menu
I have just tried via VCDS to enable the green menu
I went into VCDS selected module 7 head unit then selected adaptation 10 then selected channel 8 and read values Then I get an error "channel 8 not available" Am I doing something wrong? My car is an 2004 A8 4.0 Diesel. Many thanks |
thats correct, try to enter a "1" in channel 8 and click test
______________________________________________ A8 4.2TDI - Ice Silver, Comfort heated/cooled/massage Seats, Alcantara, Extended Leather pack, Ambient light pack, Solar roof, Night Vision, Lane change assist, Audi presense, Audi BrakeGuard, ACC Cruise, Blinds, Quad Air, AMI, Online services, Parking with rear Camera, Aluminium brushed inlays, Adaptive Zenons, High beam assist, Bose Sound, and more Gone but not forgotten: A8 D3 2005- AMI HDD, Audible Parking, TV, NAV, Bluetooth, Hybrid TV, Aftermarket headrest monitors, Rosstech VCDS / Vagcom |
Will do.
Here's 3 images from the VCDS
- the 08 err - entering 01 - then presing test for 01 Last edited by A8Pete; 22nd April 2016 at 06:35 PM. |
i noticed that a6's use chan 6, some have reported chan 5,
are these also greyed out whats the coding on you [07] module?
I just re-uploaded the pictures. The last ones weren't clear. What do you mean by "whats the coding on you [07] module?" Cheers |
when you do a scan with vcds you get an output for each module
such as this Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300GL047537256 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 3A7EB5AE7544B83 Part No: 4E0 910 609 A Component: Bedienteil MMI H42 0020 No fault code found. note the coding is 000002 these are options that can be changed, for each model depending on what equipment you have installed its probably not this one that has the av imputs though check out also the tuner coding. i have had a quick look through the green menu and cant see anything obvious.
coding for the [07] control head is 0000002
coding for the [57] tv tuner is 0001003 |
Ok on the control head 07
what is the result of looking at channel 11
(sorry Im new to all this) |
