Wish me luck
Hopefully driving home a D2 S8 later today
Have only a chance to look at the paperwork and check out the interior and bodywork in failing light. Not even test driven yet (later today) but hopefully all goes well. It needs a cambelt change (price negotiated accordingly) and a good detail session. A few deepish scratches on the (non-sunroof) roof and boot lid may need professional attention, so I will take it to a bodyshop that deals with ally panel repairs for an opinion. Panels are otherwise straight and true. Gearbox overhauled 10k miles ago and whilst stationary at least, changes up and down seamlessly. Does have the engine light displayed on the dash, believed to be a faulty lambda sensor as listed in the invoices, but will get the codes output to confirm if anything else. Looks like a relatively standard spec'd car (I prefer 'lightweight' ) - not unattractive, to me at least! Colour code is missing from options sticker - does this means it's a non standard colour? Mot sheet mentioned a couple of times that the engine cover 'restricted access' or something along those lines - is this normal? Mot also mentioned an oil leak - is there a usual spot for these engines to leak from ? Latterly serviced by lespauls-audivw in Woodford, London, and by RA Engineering in Reading prior to that ( they also undertook the gearbox rebuild) Finger crossed all goes well! Shirish |
Good luck |
So im back and so is the S8
Gave it a wash, clay and wax as the paint was in poor condition - a bit rushed but much better than before Only managed to cover 20 odd miles in it but have enjoyed these very much! First time v8 owner so even blipping the throttle put a smile on the face average 15.9 mpg less so but this is about the same as the Beemer I'll be moving on shortly. Loved its get up and go, but will have to get used to the loud pedal as i found it very sensitive.easy to hit illegal speeds without realising too! Few areas need attention: Smell of oil on the exhaust- last nvoice suggests leaking transmission sump - could this be it? I'd like to get a trans oil change done anyway, maybe a good time to get seen too. Previous invoice also noted 'signs of coolant stains on the engine' - not sure how I missed this when viewing it but could this be serious? Engine temps were solid at 90deg, no signs of Mayo in the oil filler either so hopefully not serious. 2-3 dings on each flank need sorting - could a PDR chap remove these or would I need to go to a specialist in Ally repairs? Recommendations in the south east (London/Herts area)? Cambelt change - are Audi recommended for Cambelt change or should I get and indie to do it - initial quote requests show they are very similar, but don't know if the Audi dealer work cover as much as an Indie. 2 front lower door trims need replacing Aside from that, it drove really well. Possibly a slight shimmy/vibration at 70 but will check wheel weights are still in place. Won't get everything seen to at once, Cambelt and trans oil change up first methinks If anyone can tell me how I can confirm the colour I'd really appreciate it! Cheers Shirish |
Welcome, looks an interesting colour though I've no idea what it is.
The burning oil smell is pretty common, usually a leaking seal on one of the gearbox output shafts, dripping onto a catalyst. In the past I got those fixed when I couldn't stand the stink any more!
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Excellent car. Welcome from me.
I'd rather drive on left |
Nice car, and welcome from me too. I do like the body colour (I'm going to call it petrol blue… ..) and that combination with the leather interior looks very nice. It's probably worth checking out the provenance of the gearbox work in time, but if it drives fine I wouldn't worry too much.
Also..
….I've sent you a quick PM..
Check the build sticker. Should be in the front of the service bool and also spare wheel well. This'll give you a load of letters A search on here will turn up a decoder for these. You will then have the paint and trim colours, plus all the bits and bobs it left the factory with.
Lovely looking car
A journey of a thousand+ (epic) miles, begins with a single step, (to the door of an 8). Lau Tzu |
Cheers all and 'Petrol Blue' is what I came up with on the drive back
The build sticker doesn't list the colour code as far as i can see - spare wheel well sticker is the same Gearbox is working fine from what i can tell - once the cambelt and gearbox leak is sorted (thanks HPSauce) and all fluids have been changed, i'll start building a slush fund in case it pops a cog Loving the non-sunroof look too although the waxing bit too that much longer Shirish |
RA Engineering is long established - they did some work on my Mk1 Golf GTI when I lived in Reading. I doubt they will have refurbished the box in house - expect they removed/installed and sent it away to be done.
Looks a nice example - well done The oil smell is difficult to get rid of completely - there's usually a weep coming from somewhere but it only needs a small amount to make it stink. I've had the rear seal on the centre diff output changed twice in the last year and it still bloody leaks!
