Go Back   A8 Parts Forum > A8 D3 > D3 - Common Faults
D3 - Common Faults Quick links to all known common faults and their solutions
Old 12th February 2016, 06:04 PM
yorkiea8 yorkiea8 is offline
Default Audi 4.2tdi p0101 error
Hello
I got the engine warning light 2 weeks ago, when I scanned it with my torque app it ready p0101 air flow sensor issue. I reset the light and hoped for the best. Well it came on again today same error. Any advise on where to go from here?
Old 12th February 2016, 06:17 PM
Either clean or replace the MAF sensor, then clear faults and rescan
Old 12th February 2016, 06:54 PM
Can you look at live data with the app ?
Old 12th February 2016, 10:21 PM
What should I clean it with? Sorry for being a bit thick. Will have a look at live data is there a voltage from the maf I should be expecting on idle for example.
Old 13th February 2016, 10:07 AM
Is it an Audi job for the part or can somebody recommended anywhere else?
Thanks
Old 13th February 2016, 12:19 PM
Go into data look at both air mass mg/str levels , at idle they should be about equal normally around the 400 mark , bring the revs up and look for them coming up as mirror image of each other , they wont be excatly the same .
Old 21st February 2016, 08:39 PM
Hi, does anyone know where I can buy replacements. It's lost all power on full throttle so I just want to replace them.
Old 21st February 2016, 08:47 PM
Is it worth a code test first ??
