Old 22nd March 2015, 07:43 PM
Default Loom to ABS ECU pin wiring diagram needed
Can anyone post me a pin wiring layout for the plug that goes into the ABS ECU on the following car please?
- 2005 FL D3 A8 LWB 4.2 petrol Quattro Auto
I want to check it as I have a wiring issue on a car that appears that it may have the pairs of abs sensor cables from a couple of wheels the wrong way around (as wired on the original factory loom).
Any help appreciated thanks guys
Old 22nd March 2015, 08:46 PM
I hope attached helps also it's not 100% clear which is for which engine but check pages 5 and 6, I think the ones that apply to you will be with ** that appear as little squares( for 4 wheell drive except 6.0l) on diagram and without #, or ##.
Old 22nd March 2015, 10:16 PM
Thanks Ainars much appreciated
