Old 23rd November 2012, 09:58 AM
oldnick oldnick is offline
Default how fast does your battery discharge ?
I recently experienced a problem with the battery going flat in a couple of days when the car was left in the garage
having found the problem [ or maybe A problem ] I recharged the battery and , in view of the fact that there is always going to be a small drain because of all the gizmo's fitted , decide to do a test to see just how fast the drain is going to be
car is currently not being used , so left it for a couple of days for the battery to settle down to it's base voltage , then tested the voltage daily for a week ; it drops by .03 volts per day , doesn't sound much but it means that a newish battery which fully charged gives 12.7 volts would drop to 12.4 volts in 10 days , which is about as low as I would want to go and be able to start a V8 on a cold morning , so no leaving it in the airport carpark for a fortnight while you go skiing !
question is....is this a normal rate of drain ? first time I have had a car with lots of electronics , my 20v has just a clock and I can go off for the winter and after 4 months it starts on the button [ so to speak ] ; is this the rate of discharge that others experience or have I got a tiny leak I haven't yet found?
if it is normal , maybe I am going to have to invest in one of those tiny solar panels that plug into the cigar lighter ?
Old 23rd November 2012, 10:17 AM
Dunno about the values of the discharge, but I've never had a problem starting the car after 2 weeks away on holiday
Old 23rd November 2012, 10:38 AM
Ditto what The_Laird says. That doesnt seem right to me.
Old 23rd November 2012, 10:57 AM
sloss's Avatar
sloss sloss is offline
It's not the voltage that starts the car, it's the Amps the battery can produce at the given Voltage.
Old 23rd November 2012, 11:04 AM
not quite !
watts is the unit of power , so applying ohms law shows power loss proportional to voltage drop !
Old 23rd November 2012, 11:09 AM
sloss's Avatar
I'm trying to point out that no matter the voltage if the CCA ain't there then it won't start the car
Old 23rd November 2012, 11:30 AM
Voltage drop does not mean high discharge rate. You need to check how much Amps or miliamps car is using with everything switched off.
Old 23rd November 2012, 01:10 PM
http://scubaengineer.com/documents/l...ing_graphs.pdf
well , it's not a perfect world and I for one don't have a SOC meter , neither am I prepared to do a temperature related SG test !
but as you can see from the above a simple voltmeter is quite capable of giving you an assessment of what is left in your battery
you can see from the graphs a battery with 12.4 volts is some 50% discharged [ neither quite the 'rest' graph nor the 'discharge' graph in this case ]
bearing in mind the increased internal resistance of both the battery AND the engine in cold temperatures I personally regard 12.4volts as a sensible minimum for cold cranking without adversely affecting the battery ; having said that my 2.8 turbo diesel is fine down to 12.3 volts at , say , 15C ; 12.2 volts , as I know from experience , isn't up to the job
but really I was hoping to ascertain whether others had a drain of the same order as me on an A8 !
Old 23rd November 2012, 01:58 PM
47p2's Avatar
47p2 47p2 is offline
You need to find the source of the drain using something like this
Once the car's asleep you remove one fuse at a time and connect the above and take readings, a time consuming job but it will eventually lead you to the drain source
Nite Blue 3.0L SE Quattro
Old 23rd November 2012, 02:44 PM
yep , been though all that [ time consuming as you say !! ] found the drain , fixed , stuck microswitch
but there is SUPPOSED to be a drain to keep the electronics going , question is , is the level I am now experiencing the normal level ??? I know in the latest mercs it is as high as 50 mA but don't know for the A8
or is there another drain source ? trying not to have to do the whole job again!
