Soft Close Doors
The N/S/R door refuses to soft close and won't lock from it's own button.
There is no fault in Vag Com (VCDS) either. Anyone know if this could be a simple fix?
Men have feelings too. For example we feel hungry..... Last edited by sloss; 17th February 2012 at 12:49 PM. Reason: Edited VDCS to VDCS I think is correct? |
It could be..
Or it could be a nightmare You'd maybe need to check the inside of the door for a loose connection. The door skin is a bugger to get off, needs some serious tugging.
Yea, could be but why doesn't it show as a fault? I'm too old to dick about trying to fix things other than a fuse.
I've got extended Audi Guarantee so probably use that. Cheers, Psyche.
Men have feelings too. For example we feel hungry..... |
Funnily enough that door started working again.
It 'soft closes' however the lock button still doesn't work! Time to get rid and go back to RR or Merc? Maybes aye and maybes naw!
