Vibration - Ideas?
Putting this out there for ideas basically.
I have an intermitent vibration when I get to about 70 - 80. (on a private road of course) FEELS like wheel balancing.. but had them done recently ( I guess I could have bashed a pothole but don't think thats the cause) Just replaced both front discs - which got rid of the braking vibration and I THOUGHT would get rid of the driving vibe - but on the motorway, its still there. What could be causing it outside of Wheel Balance and new discs? Seems to be worse under load, i.e. accelerating up a long motorway drag, as opposed to coasting where it doesn't seem bad at all. Engine revs freely.. no weird vibes or rattles from that.. am stumped!? |
Any vibration when revving the engine in neutral?
If not then it's probably a rotating mass issue, so with new disks and pads and recently balanced wheels, that leaves Wheel Bearings, CV joints and half shafts. I gonna plumb for CV joints wearing out. Have you ever had to replace split CV boots?
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
Definately something rotating. Engine revs freely and smoothly.. have tried revving engine when stationery - lovely.. and also putting the car in Nuetral when coasting and freely revving - that also makes no change. I feel the vibe still there, but not as bad as when the car is pulling.
Might plumb for a quick rebalance incase I have messed something up.. but then look into CV joints. Haven't replaced any split boots, and all looked well when changing the discs last weekend.. |
small update on this. Had another look around the wheel wells to see what I could see.. nothing obvious. No loose joints, doesn't seem any movement on the wheel. CV joints don't click to they too seem ok.
Went to the garage and thought I would inflate the tyres a little firmer than normal - and that seems to have made an improvement to be honest. Now not as pronounced and smoother at the aformentioned speeds. So that leads me to balancing then I guess.. (why else would the vibration reduce by upping the typre pressure!?) one question - I have a set of standard 18" sprt wheels with 245 tyres on them. what is the best tyre pressure. At the moment I have them in my opinion quite hard up around 36psi, which seems to have reduced the vibe (although clearly I need to go get them balanced and thats not a fix!) |
I'm running mine at 40psi as I do a lot of motorway runs and that seems to keep them happy. I found I got vibration if they dropped to around the mid-30's. Nothing serious, just enought that I noticed.
Might vary from tyre to tyre, but seems to be the same for my original sport wheels with Dunlops and the replcias with Runways (cheap, but effective). |
oh.. well I am probably a bit soft then (!) - I'll run 40 and see what its like. I always sit on the M'way too, with about 5 miles each end to Home/Work.
Defo seems a little happier being at higher pressures, just wasn't sure what the max / recommended is. |
