leaky gearbox
Folks
Need to sort a couple of leaks coming from the gearbox on the S8 - I've found the right illustrations for most of it but slightly surprised to not see more information in Etka about the flange replacement. There's no mention of the earlier part that has been superseded and no way of knowing whether there's a changeover date for the version A flange being installed at the factory? Does anyone have additional info so I don't either order a part I don't need or find I need one and can't get it for 2 days! Going to get the gearbox oil and filter changed again while we're in there - been about 3.5 years since it was all refreshed so I reckon worth doing again to remove any remaining old oil Cheers Adrian
Bump!
My output seal is leaking again too. It was replaced a couple of years ago but I couldn't get hold of a new style flange at the time. Does anyone have part numbers and/or know where I can get these?
Hiya
I have all the details at home - new flange included. Was available next day via TPS when I ordered mine recently. If you look with the dealer/TPS only the new style flange is listed - there are then 2 part numbers for seals depending on whether you're using new or old flange I realised when I was looking at it that its only centre diff oil capacity (about a litre) rather than gearbox oil so I've been avoiding using the car. Mine was supposed to be done last Friday but mate couldn't fit it in - 2 more Fridays before ADI to get it sorted! Will post part number details when I get home if that's ok?
Brilliant! Thanks loads
Do you recall aproximate costs?
I would go to Mackies or Chester Transmisdions and will request to reseal the damn thing. They will supply the replacement flange and a new seal that works with the new flange. They will also give a basic warranty in case it'll leak again. There will be no warranty if you supply your own parts. Will also work cheaper than buying from Audi/TPS since they source directly from ZF.
I'd rather drive on left |
Hi guys - iv had a look at this on the Audi ETKA in the office -currently not getting anywhere with the oe part number - I could be doing with a hand identifying it tbh - iv come up with 018 409 399b so far, but it appears theres a metal cover - if someone can confirm what diagram to look at I can work from there.
I think im on 499-90 or something along those lines |
