Minor ding to front bumper while parked. How to get it checked.
Very annoyingly, someone I know reversed into my S8 (already parked) this evening.
Pretty low speed but the paint is marked and it looks like the bumper is pushed back a few mm on the nearside. It was a modern Range Rover and with cameras, sensors etc. I haven't a clue how they did it, nor have they! I even saw them do it! Anyway there'll be no arguments over getting it fixed and paying, but I obviously want it done properly as it's just back from MJ and Nicola! So, first question, do we know anyone in my part of the world (South Bucks) who could give it the once over to check if there's anything other than cosmetic damage? And secondly, anywhere we trust to realign, repaint and ceramic coat the bumper properly? It will probably be heading back to MJ at some stage (next year?) for a few minor jobs that couldn't be fitted in this summer so might have to wait until then if there's no-one near me.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
I'm not sure how it's mounted so don't know if that's just take it off, adjust and refit to correct or whether something more complex may be needed. I'll PM MJ about that if she doesn't spot this post and comment here. There are also minor scuffs on the paintwork which ideally would need a strip, respray and new ceramic coating, but in reality are not much different to normal wear and tear from stone chips, so don't need immediate attention.
The bumper sits on a pair of collapsible rams which are designed to absorb minor impacts such as this but there is also a few mm of play in the mounting eyes on the end of the rams. It may simply be that you can loosen the bolt on the affected side and slide the bumper back forward (M12 bolt, 10mm socket head - remove the fog grille and look up inside the aperture). If loosening the bolt doesn't give enough movement then it may have pushed the ram in slightly in which case it'll need replacing with a good used one from Prestige which is a bumper-off job.
Thanks MJ I'll have a look when it stops raining!
How difficult/expensive is a bumper-off job and a new ram?
I would suggest loosening the two big bolts and seeing it if will just slide back in to position first. If not then we can consider options for getting the bumper off |
Unfortunately, with what I have to hand, a ratchet with only about a 7" handle, it won't move at all, not even a creak. Presumably these were undone to take the bumper off for the refurbishment, was there a torque setting for it or do I just basically need a bigger lever? Edit. I do have a 10mm Allen Key that is about 7" long, would it be worth trying that with something like a big pipe wrench gripping it?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 12th September 2022 at 11:42 AM. |
They were done up to 2 white knuckles with a 12" long ratchet An allen key with the wheelbrace as an extension would probably work to crack them loose
If this doesn't fix it I'll leave it for now and consider combining ram replacement with a bumper respray at a future date, probably next year.
Moved back out just far enough to be acceptable, now I need my glamorous assistant to hold it in place while I tighten it up. It's handy having a friend a few doors away who is a retired garage proprietor who also maintains his own classic car (1950s Riley). Edit. I've only loosened one side, the impact was offset, but it's not quite going back symmetrically so I'll need to get the other grille off too. Did that but it didn't make much difference, the other side didn't really want to move at all, but overall it's OK.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 12th September 2022 at 03:25 PM. |
