auto box slipping?
hi i just got a a8 and the box has been fine had few other issues with electrics it had oil light abs light and no rev counter but went back in garage and they cleaned the connections up i take it and was perfect also when i took the key out the ignition come on not properly but did until opened the door then went straight of but that was sorted as well so that only left the washer fluid warning due to broken washer jet so i fixed that so it now had no warning lights so i thought great took the car for a run then all or a sudden it just started revving and no gears let the revs come down and it would cruise slowly, so got it home, the next morning i went out did the same but when it does it on the display where it says prnd234 ect was highlighted and doesnt tell you what gear its in, it then will slip but some times can start it up and doesnt then it does i can put it in triptronic but still doesn't tell you what gear you in all the time but can normally get it into 1st and drive it but soon as it goes up the gears it seems to start it hasn't had any problems before this
when i spoke to the garage i got it off they said there is a sensor that is realy bad behind the drivers side wheel but looks more like a abs but i don't know they said its to do with gearbox loom, it seems to be when it rained as well but might be a coincident any help would be great before car is sold as spares its a 1996 3.7 sport |
It's either:
(a) a dodgy/broken switch - relatively cheap, or; (b) a broken gearbox - not so cheap |
If it started doing it on a run then I would suspect the gearbox clutches to be slipping, its what happened with mine. If it happens when youre parked and selecting gears then more likely to be the switch, but either way run a vagcom scan and see what pops up. You need to make sure the garage that sold you it is still very much responsible for the outcome too I would say - good luck too. is it a 4 speed box or an early 5 speed?
Confidence is the feeling you have before you know better . . . . Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs |
hi its a 5 speed and it does it from cold but some times it doesnt do it thats whats wierd what would i get to sell it as it is?
Sounds like a mechanical gearbox fault with those symptoms - if it was electrical (the F125 switch which is probably what they're trying to suggest) then you wouldn't get any physical slipping of the gearbox. It would just go into limp mode (all DIS gear options lit up red) and still drive more or less fine, albeit only in 3rd gear or reverse!
How long ago did you buy it? Sounds like a very close inspection of the small print of sale of goods act may be required or a visit to CAB and/or trading standards may be required. I suspect your best hope is you return the car and get a partial refund back. The cost of a replacement gearbox, done properly, will be a significant proportion of the car's value. Depending on mileage of course. If you can't stomach the £1000-1500 cost of a repair, or get your money back, then breaking would probably be the most cost effective option and depends on spec and condition etc what the forum sponsors might offer you for it. Might be worth a visit to http://www.agc.uk.com/index.html if you're down that neck of the woods to confirm it's mechanical and the potential cost to repair. Hope you get it sorted Adrian
hi it was a private swap for my subaru so havent got a leg to stand on so ill proberly sell it as it is but what would i get get?
