CV Boot replacement
Had a blow out and grease all around the inside of the wheel.
Can get Bilstien gaiters for £15, no name for £5. Anyone used generic gaiters?
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
Never used them on the '8, but have on previous motors and not noticed any difference, but then again, probably never had them long enough afterwards. I'd think you'd still get plenty of life.
But for a tenner, is it worth the chance? |
£30 for the kit from audi.
boot, clips, greese, bolt im a sucker for oem parts on my car
www.facebook.com/obdworks full genuine ross-tech vcds full genuine vag- tacho full genuine mpps flash mapping |
is there a prodecure for doing these?
Hmmmmm Check the Sticky?
Er.. I did - and I don't see anything that says Gaiter replacement ?-Plenty of stuff about drive shafts and axles but can't see where it tells you how to remove the gaiter when one is split - assuming its part of taking the drive shaft out but don't see that comprehensively described either!?
** Update** - Found a CV replacement post by using the groovy Google search - which took me here Technically this post is in the wrong section - should be moved to Axles and Steering with the other CV stuff? Last edited by harpersimon; 30th January 2009 at 09:28 AM. |
