Decel rpm fluctuation
Ok, first question on the forum for me so please be gentle.
I did a search and found a few g'box shift issues, but nothing along the lines of what I've got. When going down hill I lift off throttle completely and allow the trans to control the engine braking (where fuel use goes to zero). Instead of getting a consistent brake effect, I get a fluctuation where the engine rpms go up and down about 200rpm and I can feel the car surging slightly as the rpms fluctuate in time with the engine braking coming starting and finishing. I note the car is 2003 D3, has 120,000km's (75,000miles) and shes not had an ATF change due to dealer refusing to (I'm about to read the thread about ATF changes.) Firstly, does this make sense and any ideas? And, how do I know if the g'box map has been updated?
A8 4.2 S
I had the same problem with my 2003 D3 4.2 and I managed to fix it by checking and topping up the Transmission Fluid. My car had done 120,000 miles and as far as I could tell had never had the gearbox touched, so I followed the workshop guidelines and checked the fluid level and ended up adding almost a litre and a half of fluid. After this it was much smoother to change, but more importantly it fixed the problem I had with the revs fluctuating on over-run just as you describe.
At Work to Break: 2001 TT 8N 1.8T Quattro with a loud exhaust! 2000 A8 D2 3.7Q Non Sport Ming Blue 1999 A8 D2 4.2Q Non Sport Santorin Blue 2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather 2001 A2 1.4 TDi 2006 A6 C6 2.4 Quattro Avant Canyon Red At Work to Drive: 1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch 1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash 2008 Fiesta Sportvan x2 2002 Transit 2.4 LWB 2007 VW Crafter Recovery Truck 2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart 2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses. At Work to Hire: 4x 6 Berth Sunlight Motorhomes |
Great, thanks for the info.
I'll look into it, is there somewhere that I can find the workshop guidelines that you refer to? After reading some other posts about our trans, I thought it may have been the pedal switch or indeed a complete ATF change. Cheers
A8 4.2 S
Back to the drawing board. Any other ideas anyone?
A8 4.2 S
