Hidden Menu
On the Range Rover you can access a hidden menu on the instrument cluster that will give the list below so just wondered if the A8 had anything similar
1. Display Car's identification number, HW/SW version, construction date 2. instrument cluster self test. Will light up all lights and run all guages 3. Current consumption (liters/hour) 4. Average consumption (liters/100 km) 5. Current range 6. Remaining fuel in tank. Three sets of numbers: A/B/C. C=total amount. 7. Engine RPM / Coolant Temp (C) 8. Current Speed (kph) 9. System voltage at Term. "R" (Battery Voltage) 10. Country/Language (UK, US, Spa, Ger, Jap, etc.) 11. Units am/pm 12. Average Speed 13. ETA 14. Date of Software Mask 15. Production Diagnosis 16. "" 17. Display Vehicle Specific Data 18. Alarm Changeover (cont. vs. intermittent OBC chime) 19. Lock/Unlock 20. Correction factor for fuel consumption (nicht ändern!) 21. Reset all defect codes
. Nite Blue 3.0L SE Quattro |
Most of that needs VCDS.. There is some stuff that can be done from the hidden menu, but not a lot really, more dealer diagnostic type things.
Thanks
You press CAR + SETUP at exactly the same time and hold for a few seconds until a green hidden menu appears. It is all in techno-cryptic German, but is rather different from the Range Rovers in that it can be used to enable various options, some require additional hardware such as TPMS and oil level, others (such as adjustable ambient lighting) don't.
http://www.youtube.com/watch?v=q857HmEvu3o |
Thanks snapdragon, I might have to learn German before venturing into that
Though it's not always enabled (or at least in earlier versions of MMI).
