D3 - Common Faults Quick links to all known common faults and their solutions |
Parking Brake Fault
Symptom - Parking failure on centre display and loud beep whilst driving. If scanning with VAGCOM there will be no voltage from one of the calipers.
[b]Resolution[b] - New brake caliper required complete and possibly new parking controller. Will require coding on reinstall. |
same problem
I have exactly same problem but with the abs sensor light on together. Has been going back so manytimes to the dealer but the problem is exist... frustrated need advise
Otherwise parking ECU. |
Ensure you have the latest software on the module or replace the module. Worke for me.
How do you establish if it is the caliper or the ECM? Is swapping around the calipers for testing a possibility, or even simply plugging in the working caliper to the other side?
My local garage tested for voltage going to the connector, but nothing showed up even on the side that is working. |
Does the caliper move in and out with the motor?
Can you plug VCDS in and perform the tests?
Is the ECM attached to the caliper? I thought it was in the boot.
The caliper does not move and the motor does nothing. VCDS reports: Tuesday,13,September,2011,18:58:29:15869 VCDS Version: Release 10.6.4 (x64) Address 53: Parking Brake Labels: 4E0-910-801.lbl Control Module Part Number: 4E0 910 801 A HW: 4E0 907 801 Component and/or Version: EPB AV1C1010 H01 1010 Software Coding: 0000331 Work Shop Code: WSC 00443 210 91502 VCID: 1D3AD94ABD21 Fault Codes have been Erased 1 Fault Found: 02433 - Supply Voltage for Right Parking Brake Motor (V283) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 1 Fault Frequency: 27 Freeze Frame: Voltage: 10.35 V Count: 87 Thanks |
