HVAC Fault 01274
It also says: Air flow flap positioning motor (v71). 41-10 blocked or no voltage - intermittent.
Can anyone provide a translation so I know what to look for? Thanks
01274 - Air Flow Flap Positioning Motor (V71): Faulty
Possible Causes Wiring/Connectors from/to Air Flow Flap Positioning Motor (V71) faulty Positioning Air Flow Flap Positioning Motor (V71) blocked Positioning Air Flow Flap Positioning Motor (V71) faulty Possible Solutions Check Air Flow Flap Positioning Motor (V71) See Measuring Value Blocks (MVB) Perform Output Test Perform Basic Setting Check/Repair Wiring and Connectors Try running basic settings in the first instance, and see if the fault reappears. If lucky it will resolve itself, but if not will be a case of accessing it to check if the motor has failed or if there's a related mechanical fault in a linkage somewhere
Thanks Adrian. I'll give that a try
And it worked! Thanks so much for that, Adrian.
