EPC light / HP Fuel pressure question
Hi Folks,
i hope that all in here are doing great ! My my car is a 2006 Audi-S8, d3 4e 5.2L Im hoping that you can offer some insight on an issue - Driving home yesterday on the motorway I chose to overtake quickly and my EPC light came on. Only the EPC lamp. I backed off and drove the rest of the way home at a more leisurely rate. Switched off for about 30min, then started driving again the EPC lamp was off, then switched back on again when I tried accelerating strongly. Connecting VCDS at home i am seeing a Fuel Rail System Pressure too low Code. Notes: I have not driven on a motorway in several months but use the car weekly for 5-20-mile trips. I serviced a few and replaced the others fuel injectors about 2x years ago along with a walnut blast carbon clean. About 5k miles since then. the car generally starts well and runs well with no noticeable misfiring. The car never had the EPC lamp on previously to today. at Idle 640/min: LP fuel pressure real time data at 5.08-6.2 Bar fluctuating. HP fuel pressure at idle 29.5 bar to 32 bar fluctuating. can anyone tell me if these values are ok? Should I suspect one or both HP pumps? please review the below VCDS log and offer your thoughts? do You think that the HP pump/s are definitely an issue? Monday,05,September,2022,12:12:39:60735 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4 Data version: 20220830 DS341.0 www.Ross-Tech.com VIN: WAUZZZ4E67N003566 License Plate: AD06 YMC Mileage: 241680km-150172mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4L0) Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 1D 1E 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77 VIN: WAUZZZ4E67N003566 Mileage: 241680km-150172miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: Malfunction 0010 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 28-HVAC, Rear -- Status: Malfunction 0010 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: Malfunction 0010 65-Tire Pressure -- Status: OK 0000 67-Voice Control -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels:. 07L-910-552-BSM1.clb Part No SW: 4E0 910 552 HW: 4E0 907 552 Component: 5.2L V10/4V FSI ª0060 Revision: 5AH11--- Serial number: AUX3Z0F5397064 Coding: 01060003190F0160 Shop #: WSC 54321 123 12345 VCID: 5F98AA22BB334F03BE9-800A VINID: 9D196AAAA115187780003146184279E91A 1 Fault Found: 000135 - Fuel Rail/System Pressure P0087 - 002 - Too Low Freeze Frame: Fault Status: 01100010 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 241688 km Time Indication: 0 Date: 2022.09.05 Time: 12:07:07 Freeze Frame: RPM: 2416 /min Load: 36.1 % Speed: 49.0 km/h Temperature: 57.0°C Temperature: 28.0°C Absolute Pres.: 1000.0 mbar Voltage: 12.954 V Readiness: 0010 1001 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 K HW: 09E 927 156 B Component: AG6 09E 5,2 FSI RdW 0020 Revision: --H01--- Serial number: 0087677 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2B000EF2BF0BE3A3621-807E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB Component: ESP 5.7 allrad H46 0500 Coding: 0001627 Shop #: WSC 02313 000 00000 VCID: 2412E5CED2D52CDBA3B-8070 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0F5397064 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58EA813EDE1DB83BFF3-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. -------------------------------------------------------------------------------
Present cars Daily driver: BMW e65 730d Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry. |
