Saggy bottom
Hello all
For the last couple of days the N/S rear is a lot lower than the rest of the car if parked for longer than an hour. So much so the O/S front arch is quite high on the wheel. When the car is running, all returns to normal, I have checked all height options including Lift and it takes the car to full height and back. So...... A leaky joint or bag somewhere, is this a known fault? Not sure the gradual droop points towards a sensor fault in this case. Either way I'm pleased to see the compressor is fine and the overall system integrity appears ok. There is no groaning, hissing or over activity from the compressor, not that I can notice anyway.
'09 D3 S8 - Most of the bells and whistles (B&O, Audi Exclusive brown interior and exterior paint, soft close, ACC etc) de-flapped manifold! |
https://www.youtube.com/watch?v=n7LMtCP662I
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 29th November 2016 at 10:24 AM. |
Tevgeniy from the Russian forum did a diy fix on the air suspension. The photos are useful so you know what is involved. A new or remanufactured unit is probably the way to go.
http://as8.ru/forum/viewtopic.php?f=185&t=49741
Dang!...
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ). Silent and deadly, and very fast... But not as fast as Ian's M3P- (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ) Green. Fragile, but beautiful. (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. Last edited by tintin; 29th November 2016 at 11:10 AM. |
All too often, the light at the end of the tunnel turns out to be a headlamp on the on-coming train of disappointment. 2016 S3 Sportback |
Put the car to full height , then activate jacking mode .........do not lock the car just leave it and see if it drops at all .
I love that film! Classic.
It's most likely the air legs , it's the exposed rolled edge of the bag the tends to perish and weep , taking the car to full height exposes a different area and in some cases it either stops them from sagging or greatly increases how long it takes to sag .
You can try spraying soapy at them but in sure they have a ally shield around them so it's difficult to get them and ideally you need to be on a drive on ramp to get at it . I do lots of range rovers , Discoverys and that ....it's mostly the bags but have seen the feed pipe to the leg chaffed through or the corner valve leaking air back to the resvoir . |
