Old 15th February 2016, 05:28 PM
Default Mobius dashcam install
I have been reading dashcam reviews for ages, in the end I chose the relatively cheap Mobius camera based on some review which claim it is reliable long term.
I have been thinking where to run the wiring for a permanent installation. After looking through wiring diagrams I chose the driver's reading light switch.
It has a 12V feed, and can be operated with the switch so the camera can be switched off manually. Also I was hoping to avoid most of the pain of removing various trims to run the wire from the fuse box or cigarette lighter all the way to the roof.
Audi wiring diagrams are very frustrating. They mention one reading light plug 4-pin coming into the reading light switches, but neglect to mention the 5-wire plug going from the switches to the lights. Naturally this 5-pin plug has completely different wire colours to the 4-pin plug which feeds some wires directly into it anyway (??? thanks Audi)
So I had to use a bit of guesswork and an amp meter to figure out which wire supplied power to the driver's reading lamp in the central rearview mirror.
It turns out the red wire in the picture is an un-switched +12V feed, and the 3rd pin the green wire is the ground for the driver's side reading light. Hopefully that's all it is
Luckily i had some spare wires with the same pins, so I removed the 3rd green wire from the plug after the switches going into the mirror housing. I inserted my own wire and pin going to the negative terminal of the dash-cam lighter socket charger.
For the + feed I soldered a wire to the red pin-1 plug and soldered the other end to the + terminal of the cam charger.
The reading light no longer works but the switch now operates the dash cam charger. Working fine so far for a brief test run.
Let me know if I messed someting up, the wiring diagram is painfully confusing showing 6 light bulb type object where as there are only two reading lights in the mirror housing???
Where I got stuck is trying to prize open the plastic surround around the light switch and rearview mirror. I need just a little gap to feed through the usb power plug and cable to reach the camera at the top of the windscreen. I unbolted the two hex bolts visible under the light switch cover but that seems to have no effect, the damn thing won't budge.
Please let me know if you know how to remove this pesky plastic trim.
To be continued...
Name:	Mobius install 1.jpg
ID:	12432   Click image for larger version
Name:	Mobius install 2.jpg
ID:	12433   Click image for larger version
Name:	Mobius install 3.jpg
ID:	12434   Click image for larger version
Name:	Mobius install A8 wiring diagram.jpg
Old 15th February 2016, 06:02 PM
Here is the first picture with some wire labels (my interpretation).
Also, out of curiosity anyone know how to remove the little light bulbs in the mirror housing? The transparent plastic hatch is easy to remove but fingers won't fit in there to pull out the bulb.
Name:	Mobius install wire lables.JPG
Old 15th February 2016, 06:16 PM
On the topic of the bulbs, Brian posted on this some time ago IIRC, he used long nosed pliers with the jaws padded with foam or something similar
Old 15th February 2016, 06:50 PM
Does the cigar lighter lead have a mini USB on the other end?
My dash cam (a Transcend 220) did. So rather than attempt to tuck away the cigar lighter plug like that, I purchased a USB lead and DC-DC regulator.
This was the lead I bought, though this has a right-angled USB plug. I you need a right-angled plug check the bend direction is right for you (right-angled USB plugs are available in left and right bend):
http://www.amazon.co.uk/gp/product/B0058TW7WC
I used a DC-DC regulator like this (can't find the exact one):
http://www.amazon.co.uk/gp/product/B00GXXFBC0
I fitted the regulator (with an inline fuse) in the driver's foot-well fuse area. Then I ran the lead up behind the A-post trim, then tucked it under the roof-lining along the top of the windscreen. The trim can be a bit difficult to prize back far enough in places, but once done the cable is complete concealed except for the inch or two where it connects to the dash cam.
Old 15th February 2016, 10:40 PM
You could also take the gubbins out of the cig lighter adapter and just wrap it up in tape. They're usually only the size of a large stamp. That's how my fixed phone charger bracket runs in my A6
Without following all the tracks, I'd say some of the surplus lamps in your diagram are probably for switches, rather than bulbs you can get to.
Elsawin implies that the mirror has to come off before that trim will move. Its not very clear on how though - "use screwdriver to lever out interior mirror on left side between mounting plate and mirror base"
Old 16th February 2016, 03:56 AM
The mirror is on like a ball bearing mount and if you lever it hard enough will come off by levering forwards or backwards but it's a real pig to get back in again due to how hard the springs are on the ball bearing mechanism. I used a towel to protect the mirror whilst I levered it back on with both hands
Old 16th February 2016, 07:56 PM
Yes this is a good idea. Looks like I may have to take apart the adapter for another reason anyway. The mini-usb plug is too large to squeeze past the reading lights surround trim and the roof lining. I'll have to chop the wire off, which should be able to feed through, then re-solder it to the regulator inside the cig lighter type housing.
I actually have a spare brand new roof surround trim so now I can see that where I was originally trying to squeeze the mini-usb through it was hitting solid plastic. I still can't figure out whats holding the surround trim on so tightly even with bolts removed. it doesn't actually touch the mirror arm at all, once the little square mirror trim is dislodged the rest of the surround should be able to move.
On my spare trim it is made up of two pieces sandwiched together loosely with lots of plastic tabs that protrude through the top layer. Looks like the roof fabric is sandwiched between these two, I hope they are not plastic-welded together pinching the roof liner permanently.
This is all probably not making much sense without pictures. Its too dark now but when I get a chance I will take some photos.
Yes, perhaps I should have just gone for a connection which is ignition switched. I thought it would be cool to be able to switch the camera on/off with a button, and I like the red led on the regulator indicating its on (I have an idea how to make this light visible). I never use the mirror reading lights, plus I thought routing the cable would be easier and more hidden from that location.
Space wise, there is a ton of space in the roof so that's no problem at all. Just trying to find the most invisible way to push the cable and plug through is proving a bit tricky.
If anyone has removed the mirror/lights plastic surround non-destructively please tell me your tips. The bolts alone don't even budge it.
Jim thanks for the rubber covered needle pliers tip for the mini bulbs in the mirror, I'll give that a try.
