Go Back   A8 Parts Forum > Our Other Audi Friends > A6/S6/RS6 C6
A6/S6/RS6 C6 2004-2011
Old 11th April 2018, 07:16 PM
ulfilias ulfilias is offline
Default RS6 Gearbox - No reverse
Hi there,
i was chatting to a helpful mechanic at the local garage and he said he was looking at my gearbox (A8 4.2 D3) as it was the same/similar to an RS6 he was having a problem.
He said that forwards was fine, but no reverse gear, which sounds a little odd when i've experienced limp mode with the ZF gearboxes.
He seemed a little stuck with some of the local gearbox places not being interested, so i said i'd do some digging. Irritatingly i've not got the model and year on me, but i'm guessing someone here at least knows the odd pointer.
Based Peterborough/Cambridge area
thanks,
Lee
Current :
Previous :
Also :
Old 11th April 2018, 07:17 PM
Originally Posted by ulfilias View Post
Hi there,
thanks,
Lee
Might possibly be F125 switch (gear selector on the side of the gearbox) problems as they often start with random red lights of doom on selecting reverse only
Old 12th April 2018, 11:11 AM
I think i'm going to go see if I can get a VCDS scan as It would surprise me if a small village garage has VCDS etc
From a quick look the F125 switch shows as an error code?
Current :
Previous :
Also :
Old 12th April 2018, 11:14 AM
The F125 switch in itself is a very dumb mechanical unit so doesn't give any error information at all, but the ECUs take information from its state and do record errors as a result.
The common "early warning" would be the 01119 - Gear Recognition Signal error.
Old 12th April 2018, 12:27 PM
...and for some reason the switch seems to "react" to selecting reverse as if the change of the electromechanical contacts in passing between forward and reverse positions triggers the fault or, in some cases, "cures" it.
As HP says "Gear recognition signal" fault code is the usual indicator.
Old 12th April 2018, 03:11 PM
Just nipped down the garage to pass on Chester Autos number, but whilst there I had my VCDS in the car and did a scan.
It's a 1999 model with 98,500miles
It goes forward not problems, drives great.
Reverse gear selects on the dash and no limp mode or error flags.....It just doesn't move backwards! Apparently when it's really warm after a long journey etc it will slowly move backwards
VCDS shows nothing on the auto trans. Engine had a couple of lambda b1,s1 errors and voltage too low....a couple of errors on level, locks and headlight range....which since it probably hasn't been read in a while could well be old and it did have a low battery.
Current :
Previous :
Also :
