Old 20th April 2018, 09:55 AM
Default Help with boot lock problems ...
I'd be grateful if someone could explain how the A8's boot lock works so I can try and diagnose a fault.
As of yesterday, when I shut the boot I no longer hear the 'clunk' as the lock operates so I guess something's wrong.
I have the motored version; if I push the button, the boot closes and then reopens.
If I manually close the boot, it stays shut [thankfully] but I get the warning on the DIS that the boot is open.
Thanks - Julian
Old 20th April 2018, 10:27 AM
Mine had the pull-down (soft close) motor fail on it and did that - did it have that on yours? could be the soft close motor itself or the cable running to it (this is different to the actual boot open/close motor)
Old 20th April 2018, 05:02 PM
Sorry, I don't understand what you mean by the soft close motor.
The boot motor and cable that open and shut the boot are fine; my problem is that when the lock mechanism in the boot door comes down to meet the locking plate, there's no longer a motorised 'clunk' as the lock 'wraps around' the locking plate pin.
I'm hoping that someone can tell me what triggers the motor activation and what could have failed on my car.
Thanks & Regards - Julian
ID:	18504   Click image for larger version
Old 20th April 2018, 07:19 PM
47p2's Avatar
47p2 47p2 is offline
I think there's a micro switch in the latch part of the lock (your first picture). I had the same problem and sprayed copious amounts of WD40 in and it's worked ever since
Nite Blue 3.0L SE Quattro
Old 20th April 2018, 08:20 PM
Thanks for that suggestion; will have a look in the morning.
Julian
Old 22nd April 2018, 02:01 AM
Its called "Power Latching System" by Audi and has a bowden cable going to a small motor - see pictures attached.
Name:	Drive for Power Latching System - Overview.jpg
ID:	18558   Click image for larger version
Name:	Striker Plate with Power Latching System.jpg
Old 22nd April 2018, 08:40 AM
Julian,
There are two motors involved.
The one that Neil has pointed out is on all cars and is the one that locks the boot.
The other motor is the optional one that powers the boot lid up and down. This is for idle folk like me.
Old 23rd April 2018, 06:40 PM
So I've only just read the updates to this thread as I forgot I was going away for the weekend
It's my locking mechanism that's not working; I've just had a look and I still can't work out what's going on when the 'black box' on the boot lid comes down and fits into the slot with the pin in it
[Although I do now realise there's some sort of cable that gets pulled somehow from a motor in the boot thanks to the diagrams above].
But I presume:
a) the 'trigger' for the process is the boot coming down and the 'hook' in the boot lid box triggers the motor that
b) gets the motor to pull
c) the cable that's attached to the pin in slot.
So I guess the problem could be in any of these parts? Does VCDS have tests I can run to see which bit may not be working?
thanks - Julian
PS Just realised that I've had a few DTCs in my VCDS scans in the last six months but couldn't work out what part that was.
Code:
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H04 0040
   Revision: 00400004    Serial number:  W040411110043
   Coding: 0000249
   Shop #: WSC 02313 785 00200
   VCID: 275D9CFD963CD57EF0-8072
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel   P14H06 0070
   Subsystem 2 - Part No: 4E0 907 719
   Component: Neigungssensor  H03 0020
1 Fault Found:
00892 - Switch for Trunk Closing Cylinder (F248)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 3
                    Fault Frequency: 9
                    Reset counter: 25
                    Mileage: 373302 km
                    Time Indication: 0
                    Date: 2017.11.02
                    Time: 09:22:08
