Old 1st March 2020, 08:39 PM
Audifan Audifan is offline
Default My 01 S8
In March of 2019, I purchased a 2001 S8. The car is black with black interior and has the Recaro seats. Here are the upgrades the car received before my ownership: a B5 S4 01E 6 speed manual transmission was swapped in, aftermarket mufflers and x-pipe, euro bi-xenon headlights and carbon fiber interior trim was installed. This is the first picture I took of the car when I picked it up from the previous owner.
Here are a few pics I took of the car when I got it back home.
I did some maintenance to the car by installing new spark plugs and new D3 coils. Also I replaced the leaking valve cover gasket and while the valve covers were off, I painted them silver.
I have replaced all the interior lights to LED lights and was annoyed that there wasn't a driver side foot well light. Come to find out that the HVAC foot well trim panel was cut up where the light needs to mounted to.
Here is the replacement panel. Thank you MikkiJayne for helping me on this replacement panel.
While I removed the old panel it looks like it was separated from the vent tube part and I had to pull that part out.
I had to do some digging to find the wires for the foot well light which I eventually found but had to repair one of the wires.
Here is the new panel installed.
Name:	new panel.jpg
ID:	24387   Click image for larger version
ID:	24388   Click image for larger version
ID:	24389   Click image for larger version
ID:	24390   Click image for larger version
Name:	panel light wires.jpg
ID:	24391   Click image for larger version
Name:	valve covers.jpg
ID:	26750   Click image for larger version
Name:	S8 pick up.jpg
ID:	28416   Click image for larger version
Name:	S8 front.jpg
ID:	28417   Click image for larger version
ID:	28418   Click image for larger version
Last edited by Audifan; 14th May 2022 at 08:03 PM. Reason: added missing pictures as attachments
Old 1st March 2020, 10:52 PM
H-M3 H-M3 is offline
Welcome and well done mate! Get some megs nxt metal polish on those exhaust tips, use some 00 wool wire. Should come out a treat. Also are those 17 alloys? 20s will look pukka
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 2nd March 2020, 07:42 AM
Very nice!
And the best colour for a D2 S8 too
Old 2nd March 2020, 07:08 PM
Thanks. I'll look into getting those exhaust tips cleaned up. I might end up changing them since they are a little on the large size for my taste. Those are 18" alloys on the car. I'm not sure what brand as they are replicas if I remember correctly. I'm not a fan of big wheels and will be sticking with 18" for now.
Very nice!
I do like the color but I would love to have ming blue with black interior. We did get ming blue here in the States but only with platinum interior.
Old 2nd March 2020, 07:13 PM
Here is a sneak peak of the new set of wheels that I bought. These wheels are Neuspeed RSe10. The size of the wheel is 18" x 9" with a 40 offset. It'll be a while before I get these installed as I'm not sure what size tires to use yet.
Name:	new wheel.jpg
Last edited by Audifan; 14th May 2022 at 08:04 PM. Reason: switched picture to attachment
Old 2nd March 2020, 11:50 PM
Able to go back and work on the car some more and removed the steering wheel that was installed.
I got the correct S8 steering wheel installed and also bought a new S8 emblem .
Name:	steering wheel 5.jpg
ID:	24393   Click image for larger version
Name:	S8 steering wheel.jpg
Last edited by Audifan; 14th May 2022 at 08:04 PM. Reason: switched pictures to attachment
Old 17th July 2022, 07:08 PM
I ended up buying this valve spring compressor kit since the other two that I bought didn't work. The kit has arrived and I haven't used it as of yet.
I bought new valve stem seals and valve seal pliers.
I removed one valve seal and here is a close up picture of the old seal.
After removing the other two seals, here is a close up picture of the crud on top of the valve guides. What is the best way to clean this off?
Name:	valve seal pliers.jpg
ID:	28759   Click image for larger version
Name:	new valve seals.jpg
ID:	28760   Click image for larger version
Name:	one valve seal removed.jpg
ID:	28761   Click image for larger version
Name:	old valve seal.jpg
ID:	28762   Click image for larger version
Name:	dirty valve guide.jpg
ID:	28763   Click image for larger version
Name:	new valve compressor kit.jpg
Old 17th July 2022, 08:12 PM
Brass wire brush and carb cleaner. Make sure the bristles are actually brass and not plated steel.
Old 17th July 2022, 08:22 PM
Thanks for the info. Is this the best brush to use? Also forgot to ask, should I use oil when installing new valve seals?
Old 31st July 2022, 06:05 PM
Well this is disappointing. I quick did a pre-setup of this new spring compressor kit and I found out there will be no way that I'll be able to use it for the exhaust valves. As you can see in this picture below (I know I have it setup for the intake valves) there will be no room to use this kit for the exhaust valves because of the brake lines to the ABS unit. This is just frustrating! Now it looks like I'm going to have to remove the cylinder heads to do this job which I was trying to avoid.
MJ, do you have any tips on how to remove the cylinder heads with the engine still in the car? I really want to avoid pulling the engine out of the car.
