Okay, so something new on the D2!
Okay, so I do have an oil leak somewhere that's wafting a bit of smoke out of the drivers side front arch, just a bit. And this last week I have something new!
When I make a turn, left or right (unless it's about 2 mph!), this warning light comes up with no other lights illuminated and makes a right racket for between 5 and 30 seconds then just goes off on it's own?? It is much more likely to start squealing if the turn involves a slight change of gradient either up or down or a touch of adverse camber? I really need to find a local garage but sadly I am yet to find one that's open on the island. There must be one! Stay safe everyone and any speculation, idle or otherwise, to help me in my quest is welcome! Edit - Why do all my photos show on the squonk??
2002 D2 S8 - Avus Silver, Valcona red leather, Dark Myrtle wood inserts, Heated rear seats, Heated windscreen, Auto dim rear view mirror, Bose, Xenon Plus, Servotronic, Extended leather, Heat & UV Reflective glass & Ski hatch. Gearbox went bang but she's sleeping safely away. Last edited by Davey Blueeyes; 30th April 2020 at 09:22 AM. |
Brake fluid level - it probably needs topping up a little, although that then raises the mystery of where it has gone...
Could be well related. Brake fluid leaks out and gets on something hot - either brakes themselves hot or maybe wind blows it on exhaust etc.
Thanks MJ and ainars. I've not had a decent chance to look around it but I'm off now for three days with my son, I've never been so busy!
Brake fluid sounds plausible, as you say MJ I wonder where it's coming out if so??
2002 D2 S8 - Avus Silver, Valcona red leather, Dark Myrtle wood inserts, Heated rear seats, Heated windscreen, Auto dim rear view mirror, Bose, Xenon Plus, Servotronic, Extended leather, Heat & UV Reflective glass & Ski hatch. Gearbox went bang but she's sleeping safely away. |
I had the same symptoms - sharp turns or acceleration brought the warning light on. The level sensor is in the front of the reservoir i believe so any thing which throws the level off centre when its near the minimum level will cause the alarm to light up and then be ok when on the straight and level. As MJ says, where's it gone to is the key question? Mine was leaking from the handbrake actuation lever on the rear o/s caliper but it could be just about anywhere in your case I guess.
Depending on when you last checked the level, could just be well worn pads.... ever the optimist
