2001 S8 windscreen replacement?
Well the time has come for me to finally change the windscreen...last winters chip has become this summers crack
Having had bad experiences before with Autoglas on a Cosworth Scorpio and 2 Transporter vans I have decided to go to National Windscreens as my current insurer also uses them. Just been down to see them and was enquiring about the chances of fitting a heated screen in place of the standard one. "They don't do them for that model" was the reply. Fills you with confidence after reading the threads here and seeing pictures of same but hey-ho... It would be nice to have a heated screeen as winter is fast approaching - I find it a bit like aircon - before you have it you think it's a luxury but after having gotten used t it you don't want to be without it. And it's such a big screen to scrape! I would appreciate any comments from those of you who have had windscreens fitted...I have read the threads here and bearing in mind my previous 'form' with windscreens want to ensure I get the best job done. The Audi 'sponge' that is mentioned in another thread - is there a part number for that? They tell me my screen is green/grey - no mirror boss so it looks like that will be the one that is ordered...unless I can source a heated screen of course? And if I am able to source one will I be able to gain access to the wiring/terminals after the screen is fitted or will I need to supply the harness to National Windscreens to connect while fitting? I am going to replace the outer trim as well as apart from a little rust bubbling along the top of the trim it looks like someone has tried to pick bits of rubber from the n/side. According to a previous thread it looks like the part number for the trim is 4D0 853 299 F 01C Any other gotchas I need to be aware of? Thanks & kind regards, -=Glyn=- |
Well first time they tryed to do mine, they put old trim back in. After the 4th try to get it right, they bought a a new trim with them. So check first if they supply new trim.
In my case, after the first few trys. I made them come out with me on a test , so they could here for them selfs. The windscreen rubbing/scrapping on the pillers, as you go over a slight bump or corner. (glass to metal) First cpl of times i got fobbed with " car cant be driven for so many hrs" so they cant test drive it. Amazing tho, as after the 3rd time. They said they wanted to take it for test drive, as soon as they did it, to see if they cured prob.
I had my screen replaced in May by Auto Windscreens.
Apart from the nightmare I had with the office explaining the details it went very smoothly. The guys who changed the screen were spot on. When I showed them the thread about the noisy screen, he fitted some thicker sponge he carried on the van and the windscreen trim was supplied as well. It's been fine since, and the guys did a first class job. Couldn't fault them. |
Thanks for the replies guys...
No-one has the part number for the thicker sponge from Audi then? Is it even an Audi part?? Is the windscreen just bonded in place and is there a special sealant for bonding to an aluminium body? End of questions... Thanks & regards, -=Glyn=- |
Part numbers required:
b 357 845 955 Cutting wire for removing windows b DA 004 600 A2 2k-window adhesive set b D 009 200 02 primer for glass and paint b D 009 401 04 cleaning solution b D 000 703 A1 One set glass metal adhesive The foam is 8D0 845 237 distance piece (self adhesive) 10x5, 5x6,3 lower (3 of) 443 877 665 C Buffer (self adhesive) 11x5 mm upper Nothing stopping you doing it now Glynn!
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
Jesus wept...no wonder they call you 'Conan_the_Librariann'
<deliberate typo as you got my name wrong as well> Can I be cheeky and ask what windscreens were available for my car please? The reason I ask is National Windscreens tell me the heated screen was never an option in the S8...I am told mine will be green on grey/no mirror boss or something like that... I really must get around to installing ETKA/ELSAWin here one day... Thanks & kind regards, -=Glyn=- |
