Old 15th August 2012, 11:32 AM
47p2's Avatar
47p2 47p2 is offline
Default N263 code
VCDS Version: Release 11.11.2
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 4E0 910 401 S HW: 4E0 907 401 C
Component and/or Version: 3.0L V6TDI G000AG 0010
Software Coding: 0011773
Work Shop Code: WSC 02313 785 00200
VCID: 2B5F27728A1E11B
1 Fault Found:
006259 - Transmission Mount Valve 2 (N263)
P1873 - 001 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 113916 km
Time Indication: 0
Date: 2012.03.20
Time: 15:39:10
Freeze Frame:
RPM: 882 /min
Torque: 54.6 Nm
Speed: 0.0 km/h
Voltage: 11.86 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
Readiness: 0 0 0 0 0
I have an N263 fault code which appears to be a faulty gearbox mounting, so I have ordered a new one and should have it by tomorrow
Has anyone done this job before?
Nite Blue 3.0L SE Quattro
Old 16th August 2012, 12:27 PM
47p2's Avatar
Well according to TPS the N263 code does not tell you which side transmission valve (gearbox mounting) is faulty, so it is a guessing game. I ordered an off side and when I put an ohm meter across the terminals of the new valve it gave a steady reading of 18ohms, the old valve however gave a variable reading of between 750 and 1200 ohms, so this was the deciding factor to change this side. I never even bothered to check the readings of the other side.
A bit of a gamble really as the valves are over £230 each and once you plug in the connection TPS will not give a refund.
I've cleared the fault on VCDS so will scan in a few days time and hopefully everything will be clear.
This is the o/s mounting
It looks like salt water corrosion is the cause of the problem
Old 16th August 2012, 08:16 PM
Somerandomguy's Avatar
I am getting a similar fault, but am a little stuck on the part numbers as ETKA does not list my old part number. What was the part mumber for your old and new mounts?
Thanks
2004 A8 3.0 TDI Sport Brilliant Black
Came with: Black Valcona/Alcantara Leather, KESSY, rear blind, flappy paddle gear change, Phone Prep, TV
Added:Bluetooth, AMI, Hybrid TV, Parking plus, Ski hatch, towbar, DAB, Umbrella Holder, Reversing camera, Auto lights, Wheel refurb
Things to fix: Turbo fault, power drain
Old 16th August 2012, 08:50 PM
47p2's Avatar
The off-side part number for the valve I bought is 4EO 399 151 DH
No point giving you the old part number as it has been superseded
The two letters at the end denote which side, DH being the off-side. The near side will be the same number but with 2 different letters at the end
If you can get the car in the air and remove the electrical connection and stick an ohm meter onto the terminals and get a reading to determine which one is faulty it will save you buying the wrong one.
I would suspect the near side valve will be a little trickier to change as the exhaust in beside it.
To change the valve I raised the car on a 4 post ramp, removed the gearbox under-tray loosened the valve top bolt which is an 8mm hex Allen Key, using a trolley jack and 4' piece of tubing I raised one side of the gearbox just enough to lift it off the valve, removed the 2 x 13mm bolts which hold the valve onto the crossmember. Fitting is reversal and all in it took about 15-20 minutes
Old 20th October 2012, 11:01 PM
SIMI SIMI is offline
did you got sorted that fault? Any difference in driving or vibration in the car then its running in spot?
Old 21st October 2012, 12:14 AM
47p2's Avatar
Car is very smooth again, the new mounting sorted it out.
Before changing I was getting a vibration for around the first 15 minutes of driving when the vehicle was cold, it did seem to smooth out once the engine was heated up, also on idle when cold you could feel it vibrate through the cabin
