Old 6th September 2013, 01:36 PM
Default DPF Trap 4.2TDi
OK Guys,
I've got a flashy coil light and MIL, and more importantly, no power at all really, limp mode is a bitch!
VCDS reports Particulate Trap Bank 2 has efficiency below threshold. Looking at some other posts, a swap is going to be scarily expensive, so I'm looking at 2 options here:
1 - DPF removal and re-map
2 - Clean them myself, but that probably means I need a ramp to get to them.
Anyone got any experience on number 2? Bloody typical that it happens on a Friday afternoon when I need to drive to Manchester on Monday morning.
Or... if I forced a regenerate cycle with VCDS, might that sort it out? It'll clear , but after a bit of gas, it comes back
Old 6th September 2013, 01:53 PM
Could try giving Brotek a call, remember the guy we met at Glasgow Audi? know he does removals and remaps all the time
http://www.brotek.co.uk/
Old 6th September 2013, 04:17 PM
The DPF removal, decode and remap I had the 4.2 Tdi Q7 was well worth it.
Worked out at about £650 and would have cost more than that to fix the DPF sensor.
Car is quicker, more responsive, a little bit more fuel efficient and has developed a lovely subtle V8 purrrr...
I was a bit dubious to be honest, but now I've had it done once any can that has a DPF failure I'd take the same route no questions
I almost wish my A8 had a problem then I could justify the 'fix'...
Old 6th September 2013, 04:30 PM
As far as I am aware there is no way to physically clean them. Forced regeneration or long drive in low gear highish rpm might help depending on the sate of it.
Old 6th September 2013, 06:22 PM
A chap we knew locally has had the same issue on his Q7 and he tried the long drive high revs method and it has cleared his and not come back to date. Might be worth a try at that first Richard as the easiest fix, then a regenerate cycle next with VCDS then if no luck go down the remove, code out and remap route
Old 6th September 2013, 11:24 PM
Can't do the long drive/high rev thing as it won't let me above 2500 really as it's in limp mode. All the reports I'm reading seem to suggest that once it's at this point, unless you strip and clean them (not a guaranteed fix), then you could potentially burn the car down with a forced regen due to the increased temps as the regen on these engiines means you sit stationary for 40 minutes.
£850 all in for the stage 1 shark map and DPF removal from Brotek seems fairly reasonable and risk free (oh..and 50 free horses too)
