Old 6th February 2014, 05:04 PM
Phil303 Phil303 is offline
Default Analogue to Digital TV in 2002 S8
Is it possible to change the old and now redundant analogue TV receiver for a digital one? It's the Navigation Plus system fitted in a 2002 S8.
I'm a bit sketchy on model-specific details (RNS means nothing to me yet) as I've only just bought the car. No doubt everyone on here is well up on what the options available are.
Thanks.
Old 6th February 2014, 05:22 PM
It's almost certainly connected to an RNS-D.
The TV tuner (there are at least 2 versions) will have an Aux input that you can use for a DVD player, DVB-T tuner, reversing camera, whatever.
The problem (which I'm currently wrestling with, as have others) is mostly getting decent reception, plus all the usual stuff of where to put the aerial(s), tuner, wiring etc. and how to control it.
Or there's the RNS-E option........
Old 6th February 2014, 05:52 PM
I do like to keep things as original as possible so already I'm thinking it's not worth the expense and effort. I can't imagine there's going to be a time where I *must* watch something on TV while in the car. Being able to watch DVD's however - for the passengers, does sound tempting.
Regarding this Aux Input of which you speak… where would a DVD player have to be mounted; or conversely, can you run video from an iPod into it?
Old 6th February 2014, 05:55 PM
You can mount it wherever you like, but the actual Aux input is to the tuner in the N/S boot bay so you need to get cables to there.
Old 6th February 2014, 06:13 PM
Right, scratch that. Far to much hard work.
We'll have scintillating conversation to amuse ourselves instead.
Old 6th February 2014, 07:14 PM
Depending on where you want to connect the device in, running cables from the rear to the passenger cabin isn't that hard. You could run some phono connections to beside the rear bench in 30 minutes.
Old 6th February 2014, 07:16 PM
its not that difficult, just get a unit that has a remote eye and feed it through in to the cabin, my ir eye sits between the headrests so barely noticable, thing i paid 75 for a unit with dvd / usb / sd card
