D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out |
audi s8 part number
does anyone have access to parts numbers please
id like to check to see if the a8 and s8 rear anti roll bars are differant many thanks nath |
It would help if you gave the year but generally sport models have the same bigger diameter antirollbars as S8 and non sport models have smaller diameter ARBs. You will also find that most of the time it will be specified linked to build code rather than A/S model.
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 24th April 2015 at 12:51 PM. |
the car is a 2010 4.2 tdi
there is no listing for a sport model on the d4 chassis it is either an se or se executive |
Too many to chose from
It looks like the different cars have different ones up front while the rear is pretty standard unless you have specced it for rough roads but i would not think so.
Check your PR numbers to see what you got. If you want stiffer the armoured versions are bigger / stiffer
Del |
cheers del
found the pr code 1 bk on my service book sticker just wondered if i could swap it out for a thicker rear anti roll bar to help improve the front grip in the corners |
