Go Back   A8 Parts Forum > A8 D4 > D4 - Engine Bay
D4 - Engine Bay Everything under the bonnet
Old 20th April 2016, 02:56 PM
Default Elsa Help
Anyone got Elsawin and etka working
need to lookup
A) Labor time for changing a steering pump
B) Cost of Steering Pump
Car is a 2010 4.2 TDI V8
Old 20th April 2016, 03:41 PM
There are 2 possible pumps £1065-1176
Pump replacement made up from
Remove/reinstall 2 wheels 20WU
Remove/reinstall lower wishbones 160WU
Remove/reinstall subframe 420WU
Remove/reinstall pump 90WU
Might also require height adjustment, wheel alignment and ACC radar and night vision camera alignment.
Old 20th April 2016, 03:45 PM
thanks for that
they have come back with a price for pump , extra bits and pieces, plus labor
£2300, pump is about 870 of that plus 6.9 hours labor
Old 20th April 2016, 03:53 PM
That's over £200 per hour in labour
Old 20th April 2016, 04:16 PM
Maybe 870 plus vat for pump
Old 20th April 2016, 04:18 PM
plus the bits and pieces that will no doubt need renewing,
Old 20th April 2016, 06:41 PM
Where do you find the time units Ainars?
Old 20th April 2016, 07:11 PM
Press the button in yellow circle
Old 20th April 2016, 08:42 PM
Quite sure that button doesn't work on my install and needs vin look up
Old 20th April 2016, 09:08 PM
If the 'OK' button is greyed out, enter the VIN, press 'Start Enquiry' It will open new window with error, just close it and it will let you press OK then and proceed.
