Old 10th April 2018, 09:36 AM
Simonbartlett Simonbartlett is offline
Default Keyless handles again !
So I have decided to bite the bullet and change all my door handles to get the keyless working again.
I have just changes a door lock so I am quite happy with how to fit the door handles but I cant find any info on how to change the electronic handle / switch on the boot lid.
Can anyone help with instuctions ?
Thanks
Owner of a 2008 A8 3.0tdi SE
Old 11th April 2018, 07:19 PM
Thanks
Seek and thou shalt find. . . lots of PDF's !!
In the Common Faults section there is a tech dump which has all of the servicing and repair PDFs for D3's Link Below -
http://forum.a8parts.co.uk/showthread.php?t=9347
I would imagine it will be in "General body repairs - exterior"
Old 11th April 2018, 09:26 PM
neeldub neeldub is offline
Check out this document
http://forum.a8parts.co.uk/attachmen...7&d=1523360041
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 12th April 2018, 04:29 AM
Originally Posted by neeldub View Post
Thanks. Im quite happy with the door handles as ive just replaced a rear lock. Its the boot switch handle i am looking for instructions to change.
Thanks simon
Old 12th April 2018, 08:35 AM
Hi Simon,
I don't have first hand experience removing anything on the boot, but I wondered if Del's rear camera install may help...
http://forum.a8parts.co.uk/showthread.php?t=7596
Matt
Old 12th April 2018, 08:41 AM
Hi Simon,
Thanks im sure that will help.it will hopefully be obvious once i get in there.
Old 12th April 2018, 10:07 AM
As I said - its all in the document I alluded to!! Page 23 onwards
Old 12th April 2018, 10:18 AM
Many thanks. That's alot of info there. I have found the handles and will trawl through it to find the boot handle.
Old 20th April 2018, 08:10 PM
Well i purchaced 4 used handles from our forum sponsors and as expected got great service and they were delivered the next morning.
I have had a little opp so cant work for a few weeks so fitted the drivers handle today. So i have keyless on the driver's door again. 1 down 3 to go. Interesting that on mine only one handle has ever worked properly opening when you put your hand near and 3 you had to lift the handle twice. For the first year i thought it was tbe good one that was faulty 😶
Unfortunately the handles are more silver and my car is more grey so they arent a perfect match but it doesn't look too bad. I dont think most people will notice it but it will probably drive me mad.
ID:	18509   Click image for larger version
Old 21st April 2018, 09:10 AM
Well i did the rear drivers side hamdle this morning. Its a little trickier than the frints as its behind the window rails but with a little fiddling i managed to unplug and undo the rod retainer through the hole front outside whilst lifting the handle, this saves removing the window and window surround.
The second handle even though a little harder than the front took 45 minutes to fit and finish
ID:	18528   Click image for larger version
