Old 28th October 2016, 11:37 AM
North2007 North2007 is offline
Default ESP Warning Light - Car will not start, advice sought.
After successfully changing a turbo on 4.0 D3, it was running. Brake fuild warning light came on (car was jacked up at the front). Fluid was added, however message to seek assistance came up on the display. Scanned with Gen Ross tech VDSC:
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
18262 - Powertrain Data Bus
P1854 - 000 - Hardware Malfunction - Intermittent
18289 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request - Intermittent
The rear pads recently showed as low too on the scan.
Any advice would be appreciated, should a be checking fuses?.
Steve
2003, A8 D3 4.0 TDI
Old 28th October 2016, 11:43 AM
Are these faults logged in 01-Engine or 03-ABS?
Matt
Old 28th October 2016, 01:01 PM
Matt,
16497 - Intake Air Temp. Sensor (G42)
19591 - Intake Manifold Runner Control
ABS
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
I have the full scan, didn't want to just dump it on here.
Thanks in advance. Steve
2003, A8 D3 4.0 TDI
Old 28th October 2016, 04:22 PM
carmel120 carmel120 is offline
Hi Steve put the full vcds scan up.
Is that all the fault codes.
Trev
Old 28th October 2016, 04:36 PM
Default fault codes
[quote=North2007;119011]After successfully changing a turbo on 4.0 D3, it was running. Brake fuild warning light came on (car was jacked up at the front). Fluid was added, however message to seek assistance came up on the display. Scanned with Gen Ross tech VDSC:
Hi steve make sure you have a good car battery and correctly coded to the car,then clear all the codes one by one and see which ones return.
cheers trev
Old 28th October 2016, 04:38 PM
Friday,28,October,2016,10:54:13:12992
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 16.8.3.1
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: WAUZZZ4E54N002615 License Plate: A8
Mileage: 235700km-146457mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1E 25 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 72 76
VIN: Mileage: 235700km-146457miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 409 C HW: 4E0 907 409 B
Component: 4.0L 4V/TDI G000AGMŖ0010
Revision: <> Serial number: AUX3Z0C3114402
Coding: 0010773
Shop #: WSC 02313 785 00200
VCID: 234593F0E2E7385A81-8076
3 Faults Found:
17983 - Right Engine Mount Solenoid Valve (N145)
P1575 - 000 - Short to Plus
Freeze Frame:
RPM: 0 /min
Torque: 27.3 Nm
Speed: 0.0 km/h
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
Temperature: 10.8°C
P3135 - 000 - Lower Stop not Reached
Freeze Frame:
RPM: 0 /min
Torque: 27.3 Nm
Speed: 0.0 km/h
Duty Cycle: 87.9 %
Duty Cycle: 20.7 %
Duty Cycle: 0.4 %
Temperature: 10.8°C
P0113 - 000 - Signal too High
Freeze Frame:
RPM: 0 /min
Torque: 27.3 Nm
Speed: 0.0 km/h
Voltage: 11.70 V
Absolute Pres.: 999.6 mbar
Temperature: 9.9°C
Temperature: 10.8°C
Readiness: 0 0 X X X
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 J HW: 09E 927 156 A
Component: AG6 09E 4,0LTDI RdW 0010
Coding: 0000001
VCID: 295981D880CBE20ACB-807C
4 Faults Found:
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 20.0°C
T.B. Angle: 0.0°
Voltage: 12.72 V
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 20.0°C
T.B. Angle: 0.0°
Voltage: 12.72 V
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 20.0°C
T.B. Angle: 0.0°
Voltage: 12.72 V
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 20.0°C
T.B. Angle: 0.0°
Voltage: 12.72 V
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0420
Coding: 0008557
Shop #: WSC 02313 000 00000
VCID: 214999F8F8FB2A4A93-8074
1 Fault Found:
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H02 0120
Revision: 01203602 Serial number: AUX3Z0C3114402
Coding: 0264192
Shop #: WSC 23123 823 56694
VCID: 58BFF41CEB21AB82A4-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Shop #: WSC 00000 785 00200
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 G HW: 4E0 035 729
Component: Interfacebox H43 0770
Revision: 00000000 Serial number: 343EE037514412
Coding: 0000002
Shop #: WSC 00720 210 02493
VCID: 2C5778CC8F39F72230-8078
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
Subsystem 2 - Serial number: 322AF037502693
Subsystem 3 - Serial number: ˙˙17.01.03˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙
Subsystem 4 - Serial number: ˙˙˙˙˙˙˙
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 015 0240
Revision: 00000017 Serial number: 00000000016781
Coding: 0022531
VCID: 5ABBEE14952DB99292-800E
9 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 53
Reset counter: 144
Mileage: 235151 km
Time Indication: 0
Date: 2016.10.14
Time: 20:14:25
Freeze Frame:
Voltage: 11.60 V
Temperature: 14.0°C
(no units): 201.0
(no units): 86.0
Temperature: -80.0°C
01858 - Air Outlet Sensor; Right Center (G348)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 64
Reset counter: 183
Mileage: 235153 km
Time Indication: 0
Date: 2016.10.15
Time: 10:41:35
00711 - Left Footwell Flap Positioning Motor (V108)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 29
Reset counter: 183
Mileage: 235153 km
Time Indication: 0
Date: 2016.10.15
Time: 10:41:42
Freeze Frame:
Voltage: 13.70 V
Temperature: 15.0°C
(no units): 62.0
(no units): 89.0
Temperature: -89.0°C
00819 - High Pressure Sensor (G65)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.28
Time: 01:55:33
00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 47
Reset counter: 183
Mileage: 235214 km
Time Indication: 0
Date: 2016.10.16
Time: 10:54:02
Freeze Frame:
Voltage: 13.90 V
(no units): 210.0
(no units): 255.0
00732 - Potentiometer in Positioning Motor for Right-Hand Footwell Flap (G140)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 182
Mileage: 235283 km
Time Indication: 0
Date: 2016.10.19
Time: 18:53:15
Freeze Frame:
Voltage: 14.00 V
(no units): 116.0
(no units): 255.0
00600 - Potentiometer On Positioning Motor for Temperature Flap (G92)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 178
Mileage: 235284 km
Time Indication: 0
Date: 2016.10.19
Time: 18:54:09
Freeze Frame:
Voltage: 14.10 V
(no units): 102.0
(no units): 255.0
01857 - Air Outlet Sensor; Middle Left (G347)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 183
Mileage: 235689 km
Time Indication: 0
Date: 2016.10.21
Time: 21:26:03
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 183
Mileage: 235689 km
Time Indication: 0
Date: 2016.10.21
Time: 21:26:03
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0010001
Shop #: WSC 02311 785 00200
VCID: 2A5B7ED485CDE912C2-807E
Subsystem 1 - Part No: 4E2 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
Address 11: Engine II Labels: Redir Fail!
Component: 4.0L 4V/TDI G000AGSŖ0010
Coding: 0010773
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H08 0940
Coding: 0431707
VCID: 63C5D3F0A267785AC1-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H09 0030
Coding: 0112141
VCID: 65C1CDE8AC53066A2F-8030
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 A
Component: KOMBIINSTR. VDO H42 0060
Revision: D07 Serial number: AUDID3C3000061
Coding: 0000403
Shop #: WSC 50741 143 61874
VCID: 5CB7E80C9F1947A280-8008
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
Freeze Frame:
Fault Status: 00000011
Fault Priority: 7
Fault Frequency: 4
Reset counter: 144
Mileage: 235708 km
Time Indication: 0
Date: 2016.10.22
Time: 18:49:45
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 HW: 4E0 815 069 C
Component: Heizgeraet H06 0280
Revision: 0000000E Serial number: 00000009001484
Shop #: WSC 00000 000 00000
VCID: 59B9F118902BB28A9B-800C
1 Fault Found:
02072 - Control Module for Energy Management (J644)
004 - No Signal/Communication
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 160030480513E9
Coding: FCFEFBDE2B2104
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 C HW: 4E0 035 111
Component: CD-Changer H43 0340
Revision: 00000000 Serial number: AUZ5ZBD4013149
VCID: 1939B118D0AB728A5B-804C
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0264192
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 F HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 6260
Coding: 0000001
Shop #: WSC 12345 210 01865
VCID: 26438AE491D5CD72E6-8072
1 Fault Found:
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.27
Time: 00:30:16
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory FS H02 0010
Coding: 4063330
VCID: 244790ECE7E93F62F8-8070
2 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 144
Mileage: 64376 km
Time Indication: 0
Date: 2006.07.27
Time: 13:15:35
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 144
Mileage: 0 km
Time Indication: 0
Date: 2006.01.01
Time: 00:00:00
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H43 1060
Revision: 00000000 Serial number: 353J/047581796
VCID: 3B754B907A57609AA9-806E
2 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 144
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.27
Time: 00:10:37
02927 - DVD Read Error
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.27
Time: 00:10:28
Freeze Frame:
Hex Value: 0x3E5D
Hex Value: 0x5774
Hex Value: 0x0901
Hex Value: 0x0409
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0090
Serial number: 00000411100066
Coding: 0035840
VCID: 1D31A508C4830EAAB7-8048
2 Faults Found:
02139 - Control Circuit for Left Front Interior Lights
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 144
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.27
Time: 00:10:00
02138 - Control Circuit for Front Right Interior Lights
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 144
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.27
Time: 00:10:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: Türsteuer.FS BRM004 0080
Coding: 0028450
VCID: 5EB3E204890555B2EE-800A
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040305140015
Coding: 0000217
VCID: 275D87E096DFD47ADD-8072
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
2 Faults Found:
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 144
Mileage: 224720 km
Time Indication: 0
Date: 2015.06.22
Time: 17:15:05
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Reset counter: 144
Mileage: 184703 km
Time Indication: 0
Date: 2012.04.02
Time: 15:52:17
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 G HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0360
Revision: PROD_01 Serial number: 00000000047667
Coding: 0000011
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H06 0060
Revision: Serial number: 00000000014231
Coding: 0010101
VCID: 5DB1E50884034EAAF7-8008
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: Türsteuer.BF BRM004 0080
Coding: 0028450
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000431
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Time Indication: 0
Freeze Frame:
Voltage: 11.80 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Revision: 00000001 Serial number:
Coding: 0000002
VCID: 62CBD6F4BD7D7152CA-8036
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 C HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304EO037524595
Coding: 0000001
VCID: 204F9CFCF3F123429C-8074
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000000007380
VCID: 1F4D9F00CE8F1CBAA5-804A
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1403240272
Coding: 303030393135313035414B56413031343033323430323732
3 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 235151 km
Time Indication: 0
Date: 2016.10.14
Time: 20:18:07
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.28
Time: 02:10:50
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.28
Time: 02:11:00
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0080
Coding: 0028450
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0080
Coding: 0028450
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001008
VCID: 60CFDCFCB3716342DC-8034
2 Faults Found:
02069 - Front Parking Aid Sensors
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 184
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.27
Time: 00:46:22
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 14
Reset counter: 184
Mileage: 235708 km
Time Indication: 0
Date: 2003.02.28
Time: 02:14:37
End-------------------------(Elapsed Time: 03:40)--------------------------
2003, A8 D3 4.0 TDI
Old 28th October 2016, 04:40 PM
Trev, A new battery was fitted a few weeks, however not coded. I'll look at this tonight and code. Thanks Steve
2003, A8 D3 4.0 TDI
Old 28th October 2016, 04:54 PM
yea I think must of them are down to a flat battery.
Old 29th October 2016, 03:21 PM
Yes like said ,clear down all codes , has the subframe or steering rack been removed to do turbo , is there a electrical connector on the steering rack head ?
Is the steering wheel straight ahead when driving down a straight road
It may need steering wheel centralisation adaption
Go into abs or steering angle sensor ,under adaptations and run through centralisation procedure
When wheel straight ahead angle should show 0 degrees , turn wheel one way it should count up , turn it the other it will count up but in a minus value .
Your code for steering angle is like something is diss connected .
A few things to go at ...
Old 29th October 2016, 07:16 PM
Lee, all codes cleared. Subframe and rack remained in place, only cooling and alternator removed. New battery doesn't seem to have a code, I'll return for a batttery with a BEM code, before coding. That's for your advice.
2003, A8 D3 4.0 TDI
